Go Back   Power Hungry Performance Forum > Power Hungry Performance Product Information > Orion Reflash System for Navistar
Power Hungry Performance is the first in the industry to provide custom tuning for the 1998 to 2007 Navistar Medium Duty platform!
If you have any questions or would like more information on Orion, please post here.
Old Wed, June 16th, 2021, 11:34 AM
Originally Posted by Absolution View Post
Also as far as stock EGT's go in when I was towing up the mountains it wouldn't go over 1050 before. That was with the factory 1.0 housing and the probe right above manifold on driver side uppipe. So I figured I did have some wiggle room.
Something to ask on with this reflash system am I still able to use my nexiq to interface with the truck?
If you're peaking at about 1050 now, then yes... You've got a little room. 1150-1200 sustained under heavy load is about the max you'll want to see, with short bursts (10-15 seconds) at 1250-1300 being okay.
As for the Nexiq, that should still work just fine. I use mine on the bench all the time and I can't even count how many times I've reflashed my test PCMs.
