Go Back   Power Hungry Performance Forum > Power Hungry Performance Product Information > Orion Reflash System for Navistar
Power Hungry Performance is the first in the industry to provide custom tuning for the 1998 to 2007 Navistar Medium Duty platform!
If you have any questions or would like more information on Orion, please post here.
Old Mon, June 28th, 2021, 10:28 AM
The 250 HP tune will put your engine torque in the 570 Ft./Lbs. torque range. (These are flywheel numbers). Unfortunately, the AT 545 is just not rated for that torque output. You have a bit of an advantage being a smaller and lighter bus, but the long term solution is what you've already indicated... Replacing with a later transmission.
The MT 643 is rated for 640 Ft./Lbs. and would handle the power output nicely. You could also look at going with a heavier Allison MD 3060, which is good up to 1250 Ft./Lbs., but that would require a number of changes including PCM and any associated harness. The big issue is that the AT545 is an SAE 3 bellhousing and the MT643 or MD3000 series is an SAE 2 bellhousing. This would require conversion of the engine to transmission bellhousing adapter. CadillacKid on the Skoolie.net forum would be able to help advise on that one.
Here's a good page describing the differences in bellhousings. https://www.sbmar.com/articles/under...-measurements/
I'd say at this point you may want to just keep it at 230 for the time being. Nobody wants to replace a transmission unless absolutely necessary, and we want you to be able to travel reliably.
I hope this is helpful.
Old Mon, June 28th, 2021, 11:45 AM
Ganske Ganske is offline
Ganske is on a distinguished road
Thanks! That is helpful. I will work on getting that trans swap done before pushing more power.
Tags
diamond, dt466, hungry, logic, navistar, orion, power, reflash, skoolie, system, t444e
