Go Back   Power Hungry Performance Forum > Power Hungry Performance Product Information > Orion Reflash System for Navistar
Power Hungry Performance is the first in the industry to provide custom tuning for the 1998 to 2007 Navistar Medium Duty platform!
If you have any questions or would like more information on Orion, please post here.
  #17
Old Mon, July 19th, 2021, 07:06 PM
Absolution Absolution is offline
Rattletrap driver
Absolution is on a distinguished road
I came home for this week. I've started the install of the KC300X stage 1 .84.
Everything is drop in except you have to order a 4" 90* elbow and as previously stated fab a down pipe.
I ended up Mig welding instead of Tig since I'm going to be covering it up with header wrap and I wasn't going to waste my time. I drove it with essentially a from axle dump and touched 1,300* once running though the gears (250hp setting). Once I get the muffler hooked back up I'll pressure test the system to check for leaks on the cold side then I'll start playing around with the other power settings.
I can however say the turbo spooled way faster than before even though it's inducer side is larger.
