| Orion Reflash System for Navistar Power Hungry Performance is the first in the industry to provide custom tuning for the 1998 to 2007 Navistar Medium Duty platform! If you have any questions or would like more information on Orion, please post here. |
I just finished another series of road tests with the IAT sensor in its original place, an oil cooler that was disassembled and verified to be clean and a new viscous fan clutch adjusted two notches counterclockwise from the factory setting shown in the attached picture.
No major changes were observed, when the engine is cold at full load I see ~18psi at 2100 rpm and then as things heat up I drop down to 15ish psi. The strange part to me that makes me feel that this has to be an issue with the computer side of things is that hot or cold I am back to the spec 20lbs of boost by 2400 rpm. Next steps for me are installing a pyrometer and fuel pressure sensor. My thought is that if I can observe lower egt's corresponding with lower boost at the same fuel pressure than I'd feel fairly confident saying something is causing fuel to be pulled as the engine warms up. Other Notes: The old fan clutch certainly wasn't helping things. The new clutch is a bit quieter at idle and coolant temps don't exceed 190. Before installing the new clutch I adjusted the bimetallic spring 2 notches counterclockwise to keep underhood and coolant temps a bit lower while working everything out. The maximum IAT recorded was 137 compared to a max of 105 with the sensor draped in the airbox. While disassembling the oil cooler I did note that the oil cooler temperature valve had a 220 and 240 stamped in it. Thinking these were the open/close temps of the oil cooler I tested the valve in boiling water and then in the oven. The valve didn't open at 212 submerged, started opening around 220 dry (13mm) and was fully open (26mm) by 240 dry. While this didn't wind up being helpful for me it may be good to keep in mind that there is likely negligible cooling happening in the oil cooler until 220 EOT. Truck has had oil, oil filter, fuel separator, and fuel filter replaced as part of the troubleshooting process. The engine was replaced with a navistar renewed unit while it was still a customs and border patrol vehicle. I'm fairly confident the engine has <3k miles on it because the oil thermostat was stamped 3/17, carfax has towing and service records on 1/19 at 16k odo and the truck was sold 11/20 with 18k on the odo. The turbo and longblock seem to be new while the computer seems to be original. One of the considerations I have had is whether there could be a mismatch between the newer engine and the original ecu. Last edited by bighorn466e; Fri, May 20th, 2022 at 04:18 PM. Reason: added fan clutch picture |
I realized that I never gave an update here!
I wound up getting 6th gear enabled and purchasing an Orion shortly after my last post. I took the truck and Orion out to do some unloaded pulls and compare behavior, other than getting the brakes a bit warmer than I wanted everything went far better than expected. After running through some power from acceleration calcs I found that the factory 230 rating matched up with the Orion 190 with the difference that the problem described earlier was gone. I then moved to the 250 tune and my overly simplified calcs showed a 26% power increase with EGT's staying below 1250. Life seemed good. Next time I towed with the camper and checked the datalog I noticed that my EOT was creeping quite high and I was getting the feeling of a bit of power loss. After the trip I pulled the thermostat element out of the oil cooler, did a change with t6 and got a clean bill of health on the old oil from blackstone. The next trip was quite long (FL->DE) and there were significant ambient temp changes. I noticed that on the cooler days I was getting about a MPG better and didn't feel like I was losing any power on the top of long grades. This was a bit of an eureka moment as I was losing ~12% mpg and 12% of 250 is 30hp which happens to be about the power consumed by my mechanical fan according to some engineering spec sheets. EOT tracks almost perfectly with coolant temp and I'm not noticing any significant difference in warm up times although I've only had the truck down to 50ish degrees since pulling the thermostat. Next planned step is to get drive, boost, outlet temp, intake temp, and egt datalogs to Bill from the factory turbo setup. I have a feeling that we are going to discover that we are quite far out of the ideal efficiency island of the factory turbo once we have the data in hand. If that's the case my WAG is that I'll wind up upgrading to an s364.5sxe turbo with a 0.91 housing. That may change once I have the numbers to better estimate what would be a good fit for the engine. Last edited by bighorn466e; Thu, November 3rd, 2022 at 09:47 AM. Reason: spelling |
The power increase with the fan on vs off is huge. On long hills I have left it on, and turned it off after speed stabilized and it will typically gain 5-7mph. I know kitmasters has a fan that is like ~20% on at all times, and then 100% on when called for. I think that would be the real ticket. OR perhaps a big electric pusher fan, and then bring in the mechanical when necessary. What year is your truck? I have been heavily considering swapping out my VT365/A2500 for a ~03-05 ish DT466/A3000. I assume loaded with the 5th wheel you are in the ~22klb range? How does it pull tuned at that weight? --Jeff |
