Old Wed, October 18th, 2023, 09:38 AM
PHP Ward's Avatar
PHP Ward PHP Ward is offline
Super Moderator
PHP Ward is on a distinguished road
cleatus12r is correct. The Hydra will override whatever is in the PCM, so that shouldn't be an issue. If you want to send your tunes list over to support@phptune.com, I'd be happy to double check the tunes list to make sure you have the correct files.
If you get the injectors tested and you've still got issues, give us a shout!
- Ward
PHP Support
  • 1996 F250 7.3L
  • 1995 F150 5.8L
