Old Sat, March 29th, 2025, 08:25 AM
Before spending money on different tuning for your (what I assume from your list of parts) 1995-1997 7.3L, run the tuning you have and see how it goes. The tuning for stock AA injectors and tuning for larger singles with stock nozzles will start out identical and most higher-horsepower calibrations for stock AA injectors "call for" more than what the stock injectors will provide anyway.
Stock and lower HP calibrations will run identically to what you had before and the higher HP calibrations will run stronger. I don't see a charge air cooler ("intercooler") in your list; stock injectors with additional fuel can get you into the danger zone of exhaust gas temperature under certain conditions and more fuel will only make it worse. I have two 1995s that would push almost 1200 degrees on a long climb with AAs and mild tuning. After CAC installs (from 1999 donors), 1000 is all either will ever hit regardless of load, ambient temp, or RPM.
Old Sat, March 29th, 2025, 09:25 PM
asajay's Avatar
asajay asajay is offline
Old But Sexy
asajay is on a distinguished road
Thank you for that advise to try what I have, it may work. I'm still a day or two from completion and firing it up.
Further information if helpful.
I purchased the Hydra Chip in 2017 and the tune package is VDAB0_02.
It would be nice to see a complete listing of all the available tunes if it were available. That is without having to plug into a live system. I'm still putting the wiring back together in the front end after having re-installed the radiator core support.
I printed the current tune list way back when I first programmed it. The list is:
01 - Server File: VDAB0_02: 65 HP - Daily Driver
02 - Server File: VDAB0_02: 80 HP - Daily Driver
03 - Server File: VDAB0_02: 65 HP - Performance
04 - Server File: VDAB0_02: 80 HP - Performance
05 - Server File: VDAB0_02: 80 HP - Towing
06 - Server File: VDAB0_02: 65 HP - Towing
07 - Server File: VDAB0_02: 40 HP - Towing
08 - Server File: VDAB0_02: 25 HP - Towing
09 - **BLANK**
10 - **BLANK**
11 - **BLANK**
12 - **BLANK**
13 - **BLANK**
14 - **BLANK**
15 - Server File: VDAB0_02: 0 HP - Whisper Mode
My Box Code is S0D4 and it was updated in 2017 by Bill Cohron before sending back to me.
Also thank you for the note about EGT. I had thought of putting in a gauge and I think you've convinced me I should. No, I do not have an Intercooler installed, that just seemed like one step too far. At least for now.
Thank you,
Asa Jay
1994.5 F250 Powerstroke XLT w/ZF 5-speed manual
