Old Wed, May 27th, 2009, 12:29 AM
onefitty onefitty is offline
F-150 Fanatic
onefitty is on a distinguished road
EDIT: Nevermind, Bill responded pronto. Thanks again Bill.
  #92
Old Wed, May 27th, 2009, 01:04 AM
Jason,
Not all invoice numbers are populated in the "to do" pile. There are huge gaps where dealers, chip purchases, and other orders may be missing. Also, not every invoice gets custom files and not everyone has provided HEX codes. Even they you may be 47 back by invoice number, you may only be 17 back... as is the case with your order.
Normally I can get 5-8 orders completed a day. However, with Corey's surgery tomorrow (today!), I am going to be away from the computer quite a bit over the next couple days. I'd expect at this point your tunes will be done either this weekend or the first of the week.
Hope this helps.
  #93
Old Wed, May 27th, 2009, 03:23 AM
Jon Roseman Jon Roseman is offline
Jon Roseman is on a distinguished road
Bill,
I was just wondering if you guys have everything for my order. I originally ordered my tune on March 3rd but then you later asked me for my hex code so that you could finish it up. I tried to PM you and corey but I didn't get a response. I know you guys are swamped but just wanted to know if you had everything you needed.
thanks a ton,
Jon Roseman
P.S. the canned tunes are working great by the way. I was at the 1/8 mile track and blew up a couple monte carlo and a couple of others.
  #94
Old Wed, May 27th, 2009, 09:20 AM
jjntj2003 jjntj2003 is offline
jjntj2003 is on a distinguished road
plugged my gryphon up it says they are working on invoice 1620 mine is 1623 hopefully it won't be long now . hope everything goes well with the surgery! speedy recovery corey
this is the message it shows for mine
No attached device was located.
Using registered device Serial Number 1623.
Serial Number 1623 was not located on the server.
For further update information, please contact Power Hungry directly.
Current working invoice number is: 1620.
Update information was last updated on: 05/26/2009.
  #95
Old Wed, May 27th, 2009, 09:57 AM
Thanks, jjntj2003 - this, and Bill's response above, tells me how the system is working. You're right, with an invoice number that close to the "current" one, you are practically next up. Once Bill completes your tunes, it should "find" your serial number. But - now I'm a bit confused. is 1623 your invoice number or your serial number? I would not expect them to be the same.
Jon - make sure you update Pegasus and then go to Help->Registration and fill in all the details! That way you'll know Bill has the information he needs! The HEX code he needs is called "Calibration" in the registration dialog.
To everyone: Bill has started a new thread that deals specifically with Pegasus. It's here: http://dygytalworld.ehost-services13...ead.php?t=1173 Please stop using this one for Pegasus posts and use the new one.
Last edited by Jackpine; Wed, May 27th, 2009 at 10:07 AM. Reason: Added link to new thread.
  #96
Old Wed, May 27th, 2009, 10:11 AM
that is the serial number it is the same as my invoice. that was on my desktop it would not connect hooked up to my laptop itconnected fine
  #97
Old Wed, May 27th, 2009, 10:52 AM
Well well! I just checked my invoice (I save everything) and guess what? The invoice number IS the serial number. POO! This means that if Bill is currently working on 1620, he could still be 100 away from 1623. That's unfortunate. I was hoping the current working invoice number would be more "informative".
However, I just had a thought. Maybe the Gryphon serial numbers are in sequence, beginning with the first ones ordered, (mine was 1047), and are "assigned" as the units are shipped. In this case, invoice number IS meaningful.
Old Wed, May 27th, 2009, 01:01 PM
F-150 Fanatic
WOOHOO!!!! My Tunes are in! Thanks BILL! I don't know where you find the time man, especially between taking your wife in for surgery and all the other stuff, pretty amazing...
I have uploaded the custom calibrations to the gryphon, and it all went successfully, but now the gryphon screen says :
Connecting to Bridge.
Please wait...
It has been on this screen for about 5 minutes now. Do I need to do anything?
  #99
Old Wed, May 27th, 2009, 01:51 PM
Please wait...
Is your truck a 97-03? If so simply disconnect the unit and reconnect to the truck.
  #100
Old Wed, May 27th, 2009, 02:27 PM
Lars gave you the correct answer here, but I did find one instance where something didn't work out quite right (but the member never said what the fix was). Let us know if everything is working correctly, OK?
