Old Fri, December 18th, 2009, 08:40 AM
Originally Posted by strokin96 View Post
Have you heard anything about Rosewood's DIY injector nozzle swap kit? I was wondering if installing these would provide enough fuel for one of the 140 HP tunes
If you're just looking to swap nozzles on your otherwise stock AA injectors (assuming you have a '96) then no, they're not going to help too much. Unfortunately you don't have enough fuel volume to make that much more power because your injectors will be empty long before any sizable increases are made.
Old Mon, January 25th, 2010, 03:06 PM
Just thought I would add that my 2000 International 4700 T444e with an engine build date of 5/12/1999 had AD code injectors... Just got them out again to change the leaking injector sleeves.
Back after many years.
2003 F250 CC LB 4x4 7.3PSD
Minotaur user.
Tags
ford, heui, hybrid, injector, modified, power, shot, single, split, stroke
