Old Tue, November 10th, 2009, 09:25 PM
John Anderson's Avatar
John Anderson John Anderson is offline
John Anderson is on a distinguished road
Why not just soften the throttle table a little. You would have to basically push much harder to the same amount of power. Everything above half throttle could be the same, but below kill it by about 10-15 percent.
www.littlepowershop.com 1-877-227-0823
Old Tue, November 10th, 2009, 11:00 PM
From post number 2:
.........for the most part the only thing you can do to keep from spinning is using a stock program or less than stock power levels.
Exactly my thinking, John!
Old Wed, November 11th, 2009, 12:03 AM
Just get yourself some of these:www.mattracks.com
Then you will be able to go anywhere!
J/K!!!!!
LOL's
Old Wed, November 11th, 2009, 01:49 AM
There isn't any real mechanical harm in "retarding" the start of injection when the engine's cold. As far as retarding the SOI goes, it's not really "retarding" since it's more accurate to say that it's just less advanced. A lot of folks sell quiet tunes....even PHP has a Whisper Mode. Incorporating less advance in both the Start Of Injection for RPM vs. EOT and the Start Of Injection Delay for EOT vs. ICP maps allows the PCM to delay the commanded injection event slightly for the thinner oil when cold since the whole reason that map is there is because of the oil viscosity along with slower combustion rates and longer ignition time. Using 5W/40 oil when cold results in a "faster" injector than one utilizing 15W/40 at the same temperature therefore less advancing of the timing is necessary.
The noise level will always be slightly higher with a colder engine because it is working harder just to stay running. The drawbacks to not enough injector "lead time" when cold could be harder starting, white/bluish smoke, and sluggish performance. It takes quite a bit of "less SOI advance" to get these drawbacks so once you get to the hard starting or smoking, you've gone too far with that particular truck. Too much SOI advance is definitely audible and it's something that should be avoided for fear of a junk engine.
If you've ever heard of people recommending being easy on the engine while it's cold, it's because of these EOT related maps. There is A LOT of "advancing" going on there. Add into that the increased SOI of aftermarket tuning (RPM vs. Mass Fuel Desired) and you get some pretty awesome timing.
For me the truck gets extremely loud during cold startup and easy driving even after extended idle time. I realize that the EOT is not up to temp yet which is why it is like this, but it really does not sound healthy at all. It has really concerned me. Keep in mind that I am running Hybrid injectors and know that it will never be as quiet as it was with the split's in there. So if I understand correctly if the truck is properly tuned when cold the idle and cruising noise levels should be similar to when the truck is warmed up? And its possible that I can be doing more harm to the engine with this (advanced SOI) than I could be with it less advanced? The white/blue smoke does not bother me much as I no longer have the intake air heater, fuel heater, or EBPV anymore and those all aid in reducing that. EPA probably wont like me much but I dont mind.
Ok, so how about doing the same thing (lessening SOI) on a warm engine to reduce engine noise. What adverse effects would that have. I would assume higher EGT's and poor economy, anything else? Would be nice to have a tune for city driving where economy and EGT's are nut much of a concern anyways.
Sorry, I am green at this and trying to get a handle on things.
Old Wed, November 11th, 2009, 01:48 PM
For me the truck gets extremely loud during cold startup and easy driving even after extended idle time. I realize that the EOT is not up to temp yet which is why it is like this, but it really does not sound healthy at all. It has really concerned me. Keep in mind that I am running Hybrid injectors and know that it will never be as quiet as it was with the split's in there. I think you've realized the biggest issue. Yes, single shot injectors will inherently cause more combustion noise than split shots due to one big bang rather than the softened blow of two smaller injection events that makes a split shot what it is.So if I understand correctly if the truck is properly tuned when cold the idle and cruising noise levels should be similar to when the truck is warmed up? Not totally true, but the truck shouldn't sound like a 6.5L Chevy. If you've ever heard one of those, then that's what you don't want.And its possible that I can be doing more harm to the engine with this (advanced SOI) than I could be with it less advanced? Most of the time, this is the case. Later SOI will almost always be easier on the reciprocating assembly than earlier SOI to a point. Too late to the point of causing white smoke will wash down the cylinder walls with raw fuel and get rid of the oil barrier on the piston rings. It will also cause a severe lack of power, higer EGT (if a complete burn is accomplished), and just a waste of fuel.The white/blue smoke does not bother me much as I no longer have the intake air heater, fuel heater, or EBPV anymore and those all aid in reducing that. EPA probably wont like me much but I dont mind.
I'm not sure what you have as far as tuning goes (Minotaur, FU2, etc.) but it's not that big of a deal to slightly retard SOI in certain parts of the maps but a trained ear is ALWAYS going to be better than a stab in the dark. Live tuning is a great tool in this area because you can change stuff while you're driving instead of making 6 different programs at a time and driving each one until you get a feel for them and then making tuning changes, erasing the chip, rewriting it, and then driving again.
Old Wed, November 11th, 2009, 03:13 PM
I have custom tunes from another company, so would the Romulator be worth getting with the Minotaur package?
Still waiting on a reply from Bill to set me up with what I need.
Old Wed, November 11th, 2009, 05:23 PM
I'm glad I did it. However, I tune on the side (as a hobby for now) for other folks so it was almost a necessity.
Old Wed, November 11th, 2009, 08:51 PM
Sure wish I knew how much all this is going to cost me
Old Wed, November 11th, 2009, 08:59 PM
You don't want to know. Just give Corey your credit card information and worry about it later!
$695 for Minotaur with a chip, burner, and the binary for your truck.
<$300 for the Emulator and adapter.
You'll be in it close to $1000.
Old Sat, November 14th, 2009, 07:01 AM
Well I was hoping I had a special situation, wishful thinking I guess.
