Old Fri, December 11th, 2009, 11:19 PM
Originally Posted by Ideal150 View Post
ok sounds good. did u replace with stock ones or upgraded to something different? I know its a different topic but just curious if they make a big difference.
The best recomendation I can offer through the research I did is stick with motocraft.
Some other have tried champions or autolites and ended up doing them again after 10k-20k.
Old Sat, December 12th, 2009, 02:25 PM
Ideal150 Ideal150 is offline
Ideal150 is on a distinguished road
Will do! Thanks 88.
2.5 HBS Level Kit, Magnaflow SI/DO, PHP Gryphon, AEM BruteForce
Old Sat, December 12th, 2009, 02:53 PM
CageFighter_Dan's Avatar
CageFighter_Dan CageFighter_Dan is offline
Almost not a Newbie
CageFighter_Dan will become famous soon enough
i never thought of this before, would this effect my new motor in my truck that i swapped since it is a 2003 5.4l 2v ? it had originally the cop ignition black boots before i swapped to coil system. i have not changed them as of yet since i am waiting for my tunes first. But shortly there after this is since i do not know when or if they were ever changed in this vehicle originally. it had only 38,000 km on engine when i bought it a month ago
When the going gets tough slap it in 4wheel high and plow through the junk!
Last edited by 88Racing; Sat, December 12th, 2009 at 11:40 PM. Reason: Hit edit by accident
Old Sat, December 12th, 2009, 11:37 PM
Nope!
That's why this is posted in the 04-08 section.
If you have a 5.4 2v then this tsb does not apply.
You just have to make sure you torque yours right so they don't loosen up and pop out.
Old Sun, December 13th, 2009, 02:55 PM
Nope!
That's right! He has the spark plug ejection problem, doesn't he? You'd think, with all their experience, Ford wouldn't have created two crummy designs in a row!
Old Sun, December 13th, 2009, 11:15 PM
I don't know which is worse?
Paying for plug extraction.
Or.
Paying for the install of time serts.
Old Mon, December 14th, 2009, 11:24 AM
Almost not a Newbie
ok great thanks for the heads up with the torque, its usually 25lbs right?
Old Mon, December 14th, 2009, 11:55 AM
On your applicaction 03 5.4 2V that sounds about right.
Old Fri, December 25th, 2009, 10:24 AM
sam4msu sam4msu is offline
sam4msu is on a distinguished road
Sorry if I am covering a previously covered topic but I am new to F-150's. I just got a 2007 F-150 with a 4.2 v-6 and a manual tranny. I assume from what I have read that I do not have to worry about the "stuck/broken" plug or the plub ejecting from the housing. Am I correct in this?
Thanks.
Old Fri, December 25th, 2009, 11:26 PM
Thanks.
That's ok!
This is for 5.4L 3V motors.
