View Poll Results: 04-08 Transmission Failure Survey
2004 8 30.77%
2005 3 11.54%
2006 4 15.38%
2007 7 26.92%
2008 3 11.54%
0-50,000 6 23.08%
50,000+ 9 34.62%
Torque Conveter 4 15.38%
Valve Body 3 11.54%
Clutches and Other 5 19.23%
Multiple Choice Poll. Voters: 26. You may not vote on this poll
Old Fri, December 2nd, 2011, 03:30 AM
yhammack's Avatar
yhammack yhammack is offline
yhammack is on a distinguished road
2006 F150 5.4L
Lifted on 35's, 3.73 gear.
Transmission let go at 60k
Started slipping into 4th gear, then 2nd to 3rd, then 1st to 2nd until it finally barely moved. Few weeks before I heard a squeaking noise in the morning on cold start, then would go away after it warmed up.
Turns out the Torque Converter came apart and took out the tranny. So $1800 later I have a rebuilt tranny with shift kit and an upgraded converter. They say the fins are only spot welded on the stock converter so this new one is braised on all the fins. Hopefully it holds together longer this time.
Old Sat, May 19th, 2012, 11:40 AM
281Screw 281Screw is offline
281Screw is on a distinguished road
2007 F150
4.6L
23K rear end and trans failure shuddering clutches
53K valve body TSB, then a week later TC went out taking the rest of the trans with it 2 days out of warranty
All covered under warranty
Performance: PHP Gryphon, Troyer E-fans & UDPs, S&B CAI, Roush OR Exhaust. Hawk PC
Appearance: 4" CF Cowl hood, S331 grill, Recon smoked tails & 3rd brake, Black Rhino Rockwells, 285-75-17 Nitto TG's, Bilstein 5100s F/R
Audio: P4300, CerwinVega Vmax 10", Fusion 6.5" components, Kenwood Amps
Old Sun, June 17th, 2012, 08:46 AM
Bassdevils Bassdevils is offline
Drink beer
Bassdevils is on a distinguished road
2006 Transmission gave out as I pulled into the parking lot at work. 1st 2nd and reverse shot.
