Old Sun, March 14th, 2010, 07:35 AM
Give me a couple of days to think about what your asking?
Old Sun, March 14th, 2010, 11:52 AM
Bypass maybe? If it would fit you could weld a bypass with a similar machenism to the throttle body. With that closed the exhaust will be forced to go through the cat and o2 sensor. When it is open the majority of the gas will take the bypass because of it having the least amount of resistance. You would probably have to have 2 different tunes though. One for when the plate is closed and another when it is open because the second one will have to not only take care of the better flow but also the lack of your o2 sensor's input to adjust A/F ratios. You could also set up the bypass like some chevy exhaust that has the two pipes welded to 2 plates and the plates are bolted together. Just stick a piece of flat metal next to the seal to keep the exhaust from taking the bypass.
Old Sun, March 14th, 2010, 04:10 PM
UNITY's Avatar
UNITY UNITY is offline
UNITY is on a distinguished road
That is basically what I am going to try and do except my new question was what do I do with the O2 sensors. There will be 2 different tunes but you cant really tune one with O2 sensors and the other with out. Now what I am trying to figure out is if you relocate the O2 sensors before the exhaust cutouts will I need to modify the O2s or can I just leave them. 2 different exhaust set ups are not really a common thing for a tuner to have to tune for. At least 2 "quick" exhaust changes. Not just an "unbolt this one and put on a completely new one". I guess it really just depends on how sensitive the O2 sensors are and how effected they will be.
Old Sun, March 14th, 2010, 04:20 PM
If he is making 2 different tunes, the first will be as if the truck had a regular exhaust system and the second would be if the truck was straight piped from the headers. If you straight pipe the exhaust the O2 sensor is going to go crazy anyway if you were to leave it in there. You could probably relocate the sensor to be after the bypass. Whenever you open or close the bypass you switch tunes.
Old Sun, March 14th, 2010, 05:19 PM
My problem is where do I put the O2 sensors and do I do any thing to them?
It seems that if I have the cut outs before the cats that I should have the O2 sensors before them both right? If so, do I do that O2 sensor modification in the thread posted ^?
Yes, you must have your O2 sensors before your cutouts. I would place them around 8-12'' before the cutouts to eliminate any false reading caused by the negative exhaust pulses. Do not use the anti-fouler's on them either, they need to be in direct exhaust flow to be accurate and responsive.
As for the rear O2's, I would just leave them alone, no anti-fouler's.
Then all you would need is a "no cat" program designed to ignore the rear sensors to eliminate and P0420 codes, and a "cat" program that will watch the sensors.
Should be no sweat for Bill to handle.
Old Sun, March 14th, 2010, 05:55 PM
UNITY's Avatar
That is what I was hoping for. So it is doable to "turn off" the rear O2 sensors? Was not sure how that worked on the OBD2 systems. That would be amazing! The power...the sound
Old Sun, March 14th, 2010, 06:12 PM
Yeah buddy.........sounds like a cool project!
Regardless of what tuner you go with can you let us know how everything works out?
Old Sun, March 14th, 2010, 06:21 PM
UNITY's Avatar
I am going with PHP. I have gotten to much help off of these forums to go with some one else. Also, I am just feelin the family owned and operated business thing. Usually they give you the better service and take the time to make sure things are done properly.
But for sure I will keep you updated. I will post some videos as soon as I get it done.
Old Sun, March 14th, 2010, 08:18 PM
The family business feeling kinda grows on you doesn't it? It's like a disease that you WANT to spread.
It'll sound goooood.
Old Sun, March 14th, 2010, 11:20 PM
UNITY's Avatar
Ok, I just ordered the dual 3" exhaust cut outs. I got them with out the remote openers for now just to make sure every thing works as planned. If I like them and all goes correctly I will get remote openers so when I turn off the truck to set it to the "offroad" tune I can open the cut outs at the same time with out leaving the privacy of my own truck
http://forum.gopowerhungry.com/image.php?type=sigpic&userid=1497&dateline=1267671  536
