Old Fri, June 5th, 2009, 01:22 PM
I don't have the ability to test the FICMs, but as I understand it there is a common problem with them cracking the solder joints. I have some pictures somewhere of the components that are having the problem... just can't seem to find them right now. As soon as I locate them, I'll post them.
In the mean time, if you open the FICM up they are very easy to spot. Next to the high current connecting posts, there are 4 wirewound, current limiting resistors laying right next to each other. They are brown and are bigger than any of the other resistors. These develop solder fractures and result in decreased voltage output. In many cases, resoldering these will bring the FICM back to life.
Again, I'll post pics as soon as I find where I put them.
Old Thu, December 10th, 2009, 08:13 PM
mr.c mr.c is offline
mr.c is on a distinguished road
Default pcm/ficm tuning
I have been running the FICM that you reprogammed for me and the truck ran better but not as good as before the dealer flashed away my power. I decided to get another pcm/ecm and send that to you to program them back to the strategy that the truck came with. I have had a incompatibilty code since I put in the PHP programmed FICM. The first pcm/ecm that I got was from a '03 and I put it in to check what program that it had. My AutoEgineuity scanner showed some really wierd numbers. The program strategy number was bracketed with several y's with 2 dots over the top of them. I do not know what the CVN number is that shows up under the CAL number which is the strategy number. Anyway this pcm showed a 0 for a number. The original pcm showed 28C7D90 for the CVN.
I tried driving the truck with the different pcm and there was no tow/haul mode. The seller of the unit had listed it as for an automatic. It probably wasn't. So I bought another used pcm from an '04. That was delivered today and I put it in the truck to check to see what the strategy was. It was VXBC9N8.HEX. The same as what was current in the truck after the dealer flashed it. It showed a different CVN number 21F261D. I decided to take it for a quick drive. I felt a difference just driving it across the yard to get to the road. Very responsive to throttle. I got to the road and showered down on it and the truck took off like unleashed beagles. My truck is a F350 crew cab long bed dually with a topper. 3.73 rear gear and stock size tires (16"). A heavy truck. When it came up on boost it lit up the tires and lit them again on the second gear shift. There was a good bit of black smoke for about 50' . Thirty pounds of boost as it had before swapping pcm's. Showering down on it at 20-30 mph still resulted in tire spin and some black smoke. The power was as good as when the truck was new. I don't remember all of the smoke however.
I have a couple of questions. How could a pcm with the same VXBC9N8.HEX strategy perform so differently? What is the CVN number under truck identity? That number was different. 21F261D in this pcm and 28C7D90 for my oridinal pcm.
I still had the imcompatibility code that comes up for this unit as well. I still am planning on sending you a pcm and a new ficm for you to reprogram back to original (as sold) specs. I was going to send the replacement unit and keep the original pcm as is but after driving the truck with the spare pcm, I am not so sure. Am I in any danger of hurting the engine with this spare pcm that makes good power? Fuel mileage is an unknown on this unit since I just got it this afternoon.
Old Thu, December 10th, 2009, 09:01 PM
Jeremy's Avatar
Jeremy Jeremy is offline
Spark Plug Inhibited
The second PCM you bought could have a program on it. What year is your truck? build date?
The first PCM you bought would be for an auto if it had three connectors on it. The six speed PCM has two.
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Thu, December 10th, 2009, 09:34 PM
My truck is an '04 with a 11/03 build date.
Old Sun, December 13th, 2009, 05:50 PM
cartmanea cartmanea is offline
cartmanea is on a distinguished road
Agree, I'll bet the second PCM has a custom program flashed to it.
Old Fri, December 18th, 2009, 09:38 AM
Definitely sounds like a modified ECM. The missing strategy information is usually a pretty good sign.
Old Fri, December 18th, 2009, 01:39 PM
Default ecm's
Bill: The one with the missing strategy number was the 2003 ecm. It didn't run very well and there was no tow/haul. I did some searching and found the CVN is calibration verification number. The '03 ecm showed a 0 for that.
The ecm that had good response did have a CVN.
At any rate I sent you two ecm's in case there is a problem programming the 2003 unit. I would like to use the '03 ecm if possible and leave the 2004 original ecm alone.
I do share your contempt for what the dealers are doing to our trucks. In my case I made them promise that they wouldn't flash it before I left it with them. They did it anyway. I better end this now. Getting riled up again.
You should receive a package today or tomorrow with a new FICM and 2 ECM's. Again, the second ecm is just in case there is a problem programming the '03 unit.
Old Fri, December 18th, 2009, 01:58 PM
No worries. We'll let you know when it shows up.
