Old Mon, June 7th, 2010, 09:58 PM
ChuckD's Avatar
ChuckD ChuckD is offline
Duty, Honor, Country
Do you have any laterial movementin the turbo?
Chuck
1995 Mustang GT
2004 Explorer Limited
Old Tue, June 8th, 2010, 11:27 AM
majek5's Avatar
majek5 majek5 is offline
Nothin' Stock
Yes, there is a little play. The fins do not appear to be bent or damaged. The truck had a k&n on it for at least 60,000mi. I put the tymar on it when I discovered how bad they are for a diesel. Not having seen a new wheel, I have no reference if it is "dusted".
'06 6.0 F350 CCLB KR.
stock...
Old Tue, June 8th, 2010, 01:51 PM
Tholt34 Tholt34 is offline
Tholt34 is on a distinguished road
I'm not familiar with the OBS's, but if you can't find any boost leaks and your only making about 10-12 lbs. of boost, do you think your wastegate is opening up to early or do the OBS have a wastegate since there a bigger exhaust housing then the SD's?
My other truck I had, the wastegate was weak and wouldn't only make about 5 to 7 lbs. less boost then should of b/c of the it opening. Wouldn't it get hot if it opened to soon and ran there?
2000 Ford F-250 ext. cab 4x4 6 spd. Glowshift gauges, egt, boost, and fuel pressure. FU package from PHP, 5 inch straight mbrp exhaust.
Old Tue, June 8th, 2010, 03:38 PM
majek5's Avatar
Nothin' Stock
The 10-12# of boost was while towing the trailer and the rpm was about 2500. Under no-load conditions WOT, I can hit almost 25psi. Under those conditions, short bursts, not sure what the egt's were.
stock...
Old Tue, June 8th, 2010, 05:11 PM
What was the max boost you saw while towing?
Old Tue, June 8th, 2010, 08:05 PM
majek5's Avatar
Nothin' Stock
I don't remember what it hit when it downshifted, but I'm sure it went over 15.
stock...
