Old Mon, June 21st, 2010, 10:01 PM
As I recall, pushing the [Up Arrow] causes the backlight to brighten on the Gryphon. Try that next time, rather than "rebooting" it by unplugging the OBDII cable. I think the [Up Arrow] cure causes a permanent change too.
Yep thats right.
Does it flicker when you are either cranking or about to? May be a battery issue. If it is doing it because of low voltage while cranking, the alternator will be running by the time you unplug and replug.
Old Mon, June 21st, 2010, 11:59 PM
Could be the battery.
