Old Sat, August 7th, 2010, 11:15 AM
I actually had a faded display ONCE. After I adjusted it, the problem did not reoccur. I can't explain why it happened - it was NOT the battery, or heat.
Old Mon, August 23rd, 2010, 10:08 PM
average-joe average-joe is offline
Sex alleviates tension
average-joe is on a distinguished road
I can second that,same thing happened to me, i called it the PHP vortex effect.
Quality means doing it right when no one is looking.
  #13
Old Tue, August 24th, 2010, 03:25 PM
BigSur BigSur is offline
Scientist
I too had this happen one time. I could see the screen enough to go in and check the contrast, which was set at a "normal" level. Once I played with the contrast, the screen bounced back and I haven't experienced the problem again.
  #14
Old Wed, August 25th, 2010, 01:59 AM
I have to say that I have noticed the same thing, every once in a while the contrast acts like it is too low, just enough to see it, but thats it. so I go to adjust it, and its set where I left it, and as soon as i change it either up or down it fixes itself. I set it higher than what I had before the other day so I will let you all know if i notice a difference. I believe that it was set at about 40% originally, and i moved it to 45%. hope this helps
