View Poll Results: What engine do you have?
4.2 0 0%
4.6 56 26.17%
5.4 157 73.36%
Other 1 0.47%
Voters: 214. You may not vote on this poll
Old Thu, March 5th, 2009, 12:40 PM
MercedesTech's Avatar
MercedesTech MercedesTech is offline
MercedesTech is on a distinguished road
Another 4.6 guy over here.
My 0-60 is closer to 10 seconds I think !
Also on a 6" lift, and running 3.73 gears, true 35" tires load range E (heavy SOB's !) 18" rims, and no real power mods yet. Too many other projects going on right now.
If its dry when I get home, might hop in the truck to see what I can get. Been awhile.
"In the beginning of a change, the patriot is a brave and scarce man, hated and scorned.
When the cause succeeds, however, the timid join him...for then it cost nothing to be a patriot."
_ Mark Twain
Old Mon, April 6th, 2009, 01:51 AM
Desert Racer Desert Racer is offline
Desert Racer is on a distinguished road
5.4 in mine and did a 0-60 run got a 8.6X with 35's and 3.73 gearing yet the tire size was set at 23XX which is wrong so it should be better.
2007 Supercab few mods here and there
Old Wed, June 17th, 2009, 01:34 PM
Cleatis18's Avatar
Cleatis18 Cleatis18 is offline
Cleatis18 is on a distinguished road
What altitude are you guys at? I'm at 5000 feet and I could only muster a 9.04 sec 0-60 time out of mine with my current mods. I need some custom tunes pretty bad, but then again I only have 5200 miles on mine right now. Will it be substantially better once I get near the 15k, 20k mark?
08 F-150 FX4 SuperCrew
K&N 63 series CAI
MBRP Cool Duals Cat-Back Exhaust
Gryphon Programmer
Old Thu, June 18th, 2009, 07:40 AM
BlackSTX's Avatar
BlackSTX BlackSTX is offline
Baconator
I never checked my 0-60 or 1/4 times. Perhaps when I get my programmer back I'll try a few runs on stock, and one of the performance tunes. Just have to think of where I can get some open road...requires a little drive to the farm lands to get away from traffic.
Old Fri, June 19th, 2009, 02:54 PM
Cleatis18's Avatar
BlackSTX, if you get me some 0-60 times I woudl surely appreciate it or anyone else for that matter. Mine seems really slow, even for a stocker that seems pretty slow, so I am curious what others are running. Thanks
K&N 63 series CAI
Gryphon Programmer
Old Sun, June 28th, 2009, 01:06 PM
4.6 Punisher's Avatar
4.6 Punisher 4.6 Punisher is offline
281 CI's of Punishment
4.6 Punisher is on a distinguished road
Just 2 more days and I can finally place my order for the Gryphon. Seriously can't wait.
Old Wed, August 12th, 2009, 09:28 PM
Circuit Circuit is offline
Circuit is on a distinguished road
Best 0-60 as of right now is 9.12 on Gryphon stock level 2 but I can't find a place to do it without getting major wheel spin which makes my foot let up a bit without me thinking.
Once I get as much of this 87 octane out I'll be filling it up with 94 and setting it to level 3... then I might have to buy some new tires...
Oh and the belt chirp is awesome at wot when shifting. I have never owned a vehicle that was as fast as this thing is now. I forgot I had a V8 under the hood. I used to have a 1976 Chev C20 with a 350 and my little 281 Windsor out does it hands down now.
2004 XLT SCAB / 4.6
Current: In bed lighting, K&N Drop-in, Gott's intake mod, Gryphon custom tuned
Future: Exhaust (next), UDP, eFans
Old Sun, October 11th, 2009, 02:48 AM
bustintheirazz bustintheirazz is offline
bustintheirazz is on a distinguished road
I checked mine, I am getting 7.63 for my 0-60. Im running a custom level 2 and have 33" Load range E. Does anyone know how to convert your tire size to the (mm) on the gryphon? When I do my conversion of 33" to mm I get 838.2mm. Something that I am missing?
Old Sun, October 11th, 2009, 10:30 AM
Sure - the 838.2 is your tire's diameter in millimeters. You need the circumference, so multiply that by pi, which gives you 2633.3 mm. But then, deduct some for "squish" (often about 3%) so multiply by 0.97 and you'll have 2554 mm, which is the size I'd try.
Old Sat, December 5th, 2009, 02:53 AM
If at all possible, use the manufacturers website to determine the "Rev per Mile" rating of the tire. Then to convert to millimeters, use this formula...
1609344 / Rev per Mile = Tire Circumference in mm
That helps eliminate any guesswork.
