Old Mon, January 3rd, 2011, 04:19 PM
Its worth a try, but I dont know for sure.
Also be aware, the ABS module can only be re-flashed 6 times IIRC, so try and get it right the first time.
Old Tue, January 4th, 2011, 08:28 AM
God & Guns
Well that is great Thanks
Old Tue, January 4th, 2011, 10:36 AM
As Dave has pointed out (thanks Dave!):
The SD trucks have to have the vehicle speed sensor data changed in the ABS module to correct the speedometer/odometer. You have 6 chances to get as close as you can.
The OBS trucks have the programmable speedometer/odometer module. The series of steps you listed there are to reset the speedometer/odometer on those trucks.
Either find a way to reprogram the ABS module for the tire size, buy a VSS inline correction box (such as the Tru-Speed), or do the math a suggested by Longshot270.
Old Tue, January 4th, 2011, 12:37 PM
God & Guns
Thanks for the input guys. Think I'll try that truspeed calibration. Shopping around and found it about $100 cheaper than normal list price.
