Old Wed, February 16th, 2011, 12:23 PM
Bob Bob is offline
Bob is on a distinguished road
From the shop: Oil sample shows 12% dilution...thats alot of fuel in my oil. This occured in less than 3000 miles. Currently pulling injectors to check and replace o-rings and crush washers. If nothing visible plan to have injectors tested. Mechanics tells me if that is all good, then it could be a cracked head. Hoping for the best. No word on the fuel pump yet. I test drove a 2011 6.7L yesterday, man that was sweet. Awsome power. May be my next move. Ha Ha
2006 F-350 6.0L 4X4 AFE Intake, Banks Technicooler intercooler system, turbo back MBRP 4" exhaust, 70 Horse Depaco injectors, FICM and ECM/TCM Roll back, Gryphon programmer and Custom Tunes on the way
Old Fri, February 18th, 2011, 11:17 PM
Bob Bob is offline
The shop found a bad crush washer in cylinder #4. Got it back and it runs great. I will be tearing the fuel pump out this weekend to clean and inspect it. Thanks for the input.
Old Sat, February 19th, 2011, 08:06 PM
StripperDJ's Avatar
tech man
Glad you got something figured out with it...keep me posted if i can help you with it.
Brad Scott PHP
Old Sat, February 19th, 2011, 08:28 PM
Bob Bob is offline
Brad you were a great help when I talked to you on the phone. I can only hope that my travels may bring me to GA some day. Thanks again for all the help. Bob
Old Wed, March 16th, 2011, 08:22 PM
ssredrino ssredrino is offline
ssredrino is on a distinguished road
Default check
check your oil to coolant temp
mine did this same thing when it gets warm the oil gets to hot and the injectors start mis-firing, my truck was not overheating but the oil temp was running 30-40 degrees hotter than the coolant
change the oil cooler flush the coolant system
check for a bad injector harness also
