Old Thu, December 11th, 2008, 09:35 AM
87ttopstang 87ttopstang is offline
87ttopstang is on a distinguished road
Default Programming in Cold Weather
Before I install my gryphon today, as it arrived yesterday , I thought I'd ask if there are any problems loading the new tunes in cold weather. I do not see why there would be, but I have read on another forum that there might be issues.
When I say cold, I mean -16 degrees here in Canada or 3 degrees in the US.
I'll be patiently waiting. HA HA
Old Thu, December 11th, 2008, 10:36 AM
You've read the same forums that I've read. I suspect the problem is due to low battery voltage, rather than any difficulty caused by the unit itself or the PCM being cold. Usually, electronic devices work better when they're cold, although LCD screens can malfunction then. And, we all know that cold weather kills a battery's output.
I think what I'd do in your position is hook a battery charger up on a low charge setting, say 2 amps if you have one that can deliver that kind of charge (I do). Let it sit like that for about 30 minutes to bring the battery up to a good charge state and then go ahead and try to install the Gryphon and program the PCM. I'd leave the charger connected the whole time.
Of course, Bill should really be answering this, since he knows the unit best, but I don't see how what I suggest would hurt anything. Because my truck sits for long periods (weeks) in my garage, I keep it connected to a battery tender. I've programmed the PCM without disconnecting the battery tender.
Failing the charger route, just drive the truck until it warms up completely. Then, shut it down and immediately try to install and program the PCM. Make sure all accessories in the truck are turned off first, especially your DRL's and the heater blower. (The same advice for accessories applies to doing it on a charger too).
Old Thu, December 11th, 2008, 11:20 PM
Battery voltage is definitely an issue when programming in cold weather, but according to Ford's own internal documents as well as documentation from the manufacturers of some of the components, the PCM should not be reflashed until the unit temperature is at least 35º F (3º C). This actually has to do with the way the flash memory is written, which can be unstable in colder temperatures.
The best solution, as Jack indicated, is to run the truck for a bit and allow it to reach full operating temperature. This gives the battery a chance to receive a full charge and allows the PCM to warm up internally. Also, as Jack so wisely indicated, makes sure to turn off any accessories such as the heater blower, DRLs, and radio.
One thing people also overlook is the impact PTT (Nextel) Cellphones can have on the communications. CAN is a very robust communications protocol, but the microwave emissions to and from the phone can conceivably cause an issue during programming so I'd recommend keeping it far away from the programmer. I'm not aware of any specific instance where a failure occurred, but better safe than sorry.
Thanks for catching that one, Jack!
Oh... and 3º F. is freaking COLD! Brrrrrr!!!
Hope this helps.
Old Fri, December 12th, 2008, 09:16 AM
I did allow the truck to warm up and I waited until the it was a little warmer. Worked fine and I can really notice the difference in the shifts. I am looking forward to the custom tunes.
Old Fri, December 12th, 2008, 10:30 AM
Glad you answered this one Bill -
I hadn't thought a cold PCM would be a problem and a cellphone? Sheesh! Interesting that the PCM's ROM seems to be able to "hold" its programming, once programmed, into sub-zero temperatures.
We don't worry much about cold weather in Tucson - forecast to reach 73 degrees today. :Yawn:
Old Fri, December 12th, 2008, 05:19 PM
Going down to -20C or -4F for you USA folks tonight. I wish it was 73F here.
Old Thu, January 8th, 2009, 11:25 PM
coggerwayne coggerwayne is offline
Stuck in a snow drift
coggerwayne is on a distinguished road
Default Cold Weather Issues
My display crapped out last week during cold snap ... I started pushing buttons and I think I got the contrast messed up. Brought it inside to warm up and thought I would hookup to check for updates. Warning that would erase custom files so disconnected and connected back to truck. Contrast still bad but stuck on scrren display showing HEX code of PCM. Pushed enter to continue but looks like "programmer is froze up". Will not continue on to other display. This is the first problem that could be related to the cold ... Blll probably will get back to me if he has a "fix".
Stay warm for those living north of the 40th
Old Thu, January 8th, 2009, 11:38 PM
Wayne,
As soon as I get back on Monday, I'll take a look and see what might be causing the problem. I do know that the boards have a thermistor that is supposed to self adjust the contrast based on temperature which helps cold and hot weather display. The fact that you brought it in the house to warm up and it started to display a little might mean there is a problem with the thermistor and it's not correctly sensing temperature.
As for getting stuck on the ID for the PCM, that's an odd one. I'll have to take care of that on Monday as well. I'm pretty sure that if the unit can read the PCM ID, then it should be able to continue through to the main display. Again, I wonder if the cold has anything to do with it??
Ever consider moving to the states where it's warmer??
