Old Thu, August 11th, 2011, 12:20 PM
02?
If it's the original engine, 99.99999999LMNOP% that it does.
Unless you plan on big power, no need to worry about it.
Old Thu, August 11th, 2011, 12:24 PM
02?
ARe you sure about that? haha jk,
I dont plan on too much, so I guess I should be ok .
Old Thu, August 11th, 2011, 12:27 PM
If its an 02' its got PMR's.
Buut, if for some reason the motor was changed it could have forged rods.
Check this out------->7.3 Inspection Hole for Powdered Metal Rod Determination
Old Thu, August 11th, 2011, 01:07 PM
God & Guns
Check by engine S/N located on valve cover or on the block where the oil cooler is bolted up...
Start of production through 1425746 are forged rods
1425747 through 1440712 are PMR
1446713 through 1498318 are forged
1498319 through final production are PMR
Old Thu, August 11th, 2011, 01:16 PM
Sorry, but even the serial number chart is wrong. It's bad information. I have proven it twice.
One engine was supposed to have PMRs...was forged.
One was a disappointment.
The ONLY way to know is to check.
Old Thu, August 11th, 2011, 01:54 PM
Well I will just expect them to be PMR's until I get the time to check
Old Thu, August 11th, 2011, 02:48 PM
God & Guns
Good info to know...thanks Cody
Is that the purpose of the inspection port? Or is there anything else to check when having it open? And is there any pre-steps to do before taking the plug out?
Old Thu, August 11th, 2011, 02:51 PM
God & Guns
AND...is a sure fire thing that you will be able to tell through the inspection hole...or do you have to manually turn the engine? And what is the plug above the inspection port?
Old Thu, August 11th, 2011, 02:58 PM
You WILL be able to tell through the inspection hole. However, you may need to rotate the engine a little to get a rod cap to line up.
No preparation short of finding/making a 5/16" square drive.
The plug above is coolant....you don't want to take that out.
Old Thu, August 11th, 2011, 02:59 PM
cj45lc cj45lc is offline
The plug above the is insp hole is the coolant drain plug
