Old Mon, November 28th, 2011, 12:54 AM
fastlx fastlx is offline
fastlx is on a distinguished road
Default AA's to AB's tuning help!
Hi Bill, I need some tuning. 97 f350 powerstroke, build E4OD, 4x4, adreneline hpop, 6637 filter, mbrp turbo back exhaust, 4.10 gears, new icp ipr and fuel lift pump uvc harness's, edge evo cs and edge ez module. This truck is a 97 federal truck which came with AA injectors. I swapped out the AA's for a set of AB's out of my 96 cali truck. I'm told that I need programing now becuase I installed split shot injectors. I would like some custom tunes for my edge evo cs. I have been chasing a low power on take off issue which is why all these parts have been replaced. still having issue and hope that programing may fix it. manual compression test shows all cylinders are 390-400psi. I have cylinder contribution codes for cylinders 5,6,7. All injectors have new o-rings and injectors 5,6,7 have been replaced and still have contribution code for those cylinders. truck has no power on take off then jumps up and goes at 2k rpm's and above. PCM part number is F7TF-12A650-TB. CODE TDE1. DPC-202. Let me know what ya think, thanks, Ken.
