Old Wed, November 30th, 2011, 10:52 AM
dginter dginter is offline
dginter is on a distinguished road
if Ford endorses it, that's whats goin' in then...
still dreadin' the plugs, ha ha
thanks again!
2005 F150 FX4 5.4l 3v
2" AS level, 18x9 Cannon's 5" bs, 305/65R18 Falken Wild Peaks
Gotts mod, 2-1/2" true dual with x pipe and dual magnaflows 3" tips
JVC KW-HDR710, Polk db571's, Subordnance M1500 amp, JL 10W1v2-4 10" sub
Old Wed, November 30th, 2011, 10:00 PM
I'm with 88, Techron or B12. I've never used the other one. Seafoam is only good at removing water (from the isopropyl alcohol) and even that is limited.
Old Wed, November 30th, 2011, 11:54 PM
Its good for cleaning paint brushes too.....
Old Thu, December 1st, 2011, 10:50 AM
well, truck died n just got towed of the expressway
i was getting on the expressway and accelerating and right bout 50 mph n lost all power, she dropped to about 800 rpm's, no response when pushing the accelerator pedal... pulled off the side and she was runnin' very rough like on 2 cylinders or somethin and shakin' a bit...
turned her off n now won't start.
you all think it could be something w/ the programmer? had it on level 2
did notice a lil extra tickin noise this morning but would go away w/ a rise on rpm's
placed it back to stock
hooked up to a snap on 2500 computer and shows no codes, says fuel pressure is 40 psi, removed plug and she has spark, the injector flashed
any ideas? i'm at a loss
Old Thu, December 1st, 2011, 11:19 AM
Maybe the Seafoam? I cannot imagine the tune would have this effect for any reason.
You possibly have an injector problem now that has been aggravated by that stuff. I really think your only option now is to take it to the dealer. (You should have received the "injector problem" letter from Ford.)
Old Thu, December 1st, 2011, 12:33 PM
Few suggestions....
Clean the maf
Clean the TB
Change the fuel filter
Unplug the programmer and disconnect the battery before performing the above.....after the above is completed reconnect the battery and plug the programmer back in....
Locate and inspect the fuel pump driver module.....located on the frame crossmember in front of the spare tire.....you have to drop the spare to get a good look at it and remove it from its location.....check for cracks and corrosion near plug and backside of case.....
Old Thu, December 1st, 2011, 03:00 PM
I keep forgetting the fuel pump driver, although I suspect if it were bad, you would not have 40 psi pressure. Clogged injectors though are always a possibility.
And, I take it you were not in "Limp Home Mode"? That should have turned the "wrench" light on, but a bigger tipoff is the coolant temp gauge would have been pegged on hot (even though the coolant temp is normal. (Your other symptoms sound a bit like limp home mode.)
Old Thu, December 1st, 2011, 08:37 PM
Doesn't sound like the tune based on what happened. Too bad you didn't hook it up to the computer before reflashing back to stock. That wipes the memory.
The drop to 800 RPM while going 50 is strange. Limp home mode would have dropped it into 3rd gear if I'm not mistaken. Doing so would have kept the RPMs pretty high.
Have you checked all the fluid levels?
Old Thu, December 1st, 2011, 09:27 PM
Yes, and limp home puts it on 4 cylinders, so it runs poorly, but it can be driven. I was not really too much in favor of calling it limp home.
The low rpms really just sound to me like fuel (or air) starvation, either would cut the other.
Old Thu, December 1st, 2011, 11:54 PM
That sometimes use to happen with bills canned tow tune until he tweaked the torque management tables....but he can't do that to edges tunes.....
