Go Back   Power Hungry Performance Forum > Power Hungry Performance Product Information > Orion Reflash System for Navistar
Power Hungry Performance is the first in the industry to provide custom tuning for the 1998 to 2007 Navistar Medium Duty platform!
If you have any questions or would like more information on Orion, please post here.
Old Wed, June 30th, 2021, 09:15 AM
Originally Posted by Absolution View Post
Well I went ahead and bit the bullet ordered a kc300x stage 1 for my truck. In hopes of keeping everything cool and running smoothly in the future.
Gonna be a nice setup!
Old Thu, July 1st, 2021, 11:48 AM
Absolution Absolution is offline
Rattletrap driver
Absolution is on a distinguished road
I'm really hoping that I made the right choice with the stage 1. I had read where some people had better results with the stage two buy only when they were towing and the truck was under a heavy load. I'm just curious if my lower gearing and weight would bump me into that category.
But I've pulled that trigger and we will see where it gets me.
I was also talking to my brother and I could always open up some beers take the super single off my dodge and fab up a jerry rigged compound on truck.
I could even use the mechanical fuel pump hole as an oil return.
Besides since the dodge became a property truck I dropped the sticks back to 5x012 and it could really use a 63mm sized charger now.
Old Sat, July 3rd, 2021, 03:54 PM
Rattletrap driver
I got the turbo in! KC300X 63/68/.84
File Type: jpg 210190493_523342882188776_8234354034254125615_n.jpg (83.1 KB, 18 views)
Old Sat, July 3rd, 2021, 06:03 PM
Oh, that's gonna be sweet! Can't wait to see how it goes after the install is done.
Have fun!
Old Sun, July 4th, 2021, 08:41 AM
Rattletrap driver
Minor inconveniences. ( I foresaw some of it but my brain decided to look the other way)
While the stock turbo's compressor side is gtp38 based along with the newer style flange. The exhaust downpipe flange is tp38 based.
Why does this matter? The stock down pipe won't let the new turbo drop in and work.....
TP38 sleeves the downpipe into the turbo exhaust flange.
GTP38 Sleeves the exhaust flange into the downpipe.
Without me being there, I'm not sure about my father crawling under truck to do it to swap out to the new downpipe I had ordered. He said he could swap the turbo and I was already worried somewhat about that.
I'm probably going to call him today and have him to take it to a shop local for the downpipe and just have them temporally clamp the 4" downpipe to the old turbo if he really wants to do the turbo.
I guess an expedient thing to do would be grind off the mating lip on the newer style if you couldn't replace your down pipe. You could also try to take a Dremel and cut off the lip on old style down pipe but that pipe is pretty hard and you'd be there for a minute . - For the skoolie people
Uploaded are photos of the GTP vs TP exhaust.
Old Mon, July 5th, 2021, 11:39 PM
Damn, there's a wrinkle I hadn't anticipated. Never a dull moment, I suppose.
Thanks for the pictures, though. That will be super helpful to others who might be considering the same modifications.
Old Mon, July 19th, 2021, 07:06 PM
Rattletrap driver
I came home for this week. I've started the install of the KC300X stage 1 .84.
Everything is drop in except you have to order a 4" 90* elbow and as previously stated fab a down pipe.
I ended up Mig welding instead of Tig since I'm going to be covering it up with header wrap and I wasn't going to waste my time. I drove it with essentially a from axle dump and touched 1,300* once running though the gears (250hp setting). Once I get the muffler hooked back up I'll pressure test the system to check for leaks on the cold side then I'll start playing around with the other power settings.
I can however say the turbo spooled way faster than before even though it's inducer side is larger.
Old Tue, July 20th, 2021, 09:34 AM
I gotta tell ya... That is one sexy beast! I'm surprised at how much you had to fab up on the downpipe, but I guess that's just what it is.
Can't wait to see it all finished up!
Old Tue, July 20th, 2021, 10:40 AM
Rattletrap driver
It was basically hitting the engine mounts or was hitting the transmission. The rail of the downpipe was also aiming up and forwards the cab.
Old Tue, July 20th, 2021, 02:22 PM
What a mess... Good thing you got the skills (and tools) to fix it!
