Old Tue, April 13th, 2010, 01:37 AM
Great idea! but what if i get such a boost that i end up running him over?! haha
Old Tue, April 13th, 2010, 11:17 AM
I was just thinking.
What if instead of a "Y" you put a 90˚? The engine will still be able to bring in air and if you did get going 200+ mph you would get a slight amount of boost.
If I were doing that project on a 5.4 I would cut the intake to allow the "Y" after the stock fender snorkel. That way the preferred source of airflow will be from the bumper instead of the fender. The fender would still be a source, just not as significant as the front. We also have to keep in mind that we can use a 6" inlet but the air is still having to squeeze through the rest of the intake, filter and throttle body. I remember that changes the properties of the fluid but I cant specifically remember how at the moment.
The gotts mod eliminates the largest source of airway restriction. Now you have to open up anything that has less than a 3 inch diameter...so I guess that would be the throttle body which I think is 75 mm to an 80mm. We're starting to get expensive now.
But really this is all a mute point if you aren't either hauling buns down the highway or stuck in stop and go traffic all the time.
Old Tue, April 13th, 2010, 11:57 AM
I guess I would steer clear of using anything else besides the fender hole.
Reasoning is mostly to where I live and the weather and debri. I know k+n can handle moisture but I don't think it would be to friendly to the stock panel paper filter. Adding the Y like you guy are doing might be a perfect water in let during rain or snow.
If the tubing intake could be dropped low enough where gravity would help keep the moisture out then that would be a plus.
I know 4.6 has the cylinder shaped filter.
The fender hole is the perfect spot to get away from all this.
Just some thoughts.
Peace!
Old Tue, April 13th, 2010, 03:31 PM
Just some thoughts.
Peace!
I thought about the same stuff down here. Except I worry more about dust and dirt getting sucked in. My filter has to be cleaned every 6,000 miles as it it and the ram air would only increase the amount going in. But if you live in a cleaner area it would be good.
Old Thu, May 27th, 2010, 11:28 PM
I'm really surprised this hasn't made it to the resource library?
Old Thu, May 27th, 2010, 11:35 PM
Made a thread about it in the mods section but we were busy with CS/CTS stuff at the time so it got lost in the shuffle.
Old Thu, May 27th, 2010, 11:44 PM
Im sure it would make us all feel special!
Old Fri, May 28th, 2010, 07:57 AM
It was there but only in the index.
I copied it over to there also.
Peace!
Old Fri, September 9th, 2011, 10:02 PM
eej711's Avatar
eej711 eej711 is offline
Has anyone figured out a way to have a two-way entry with the 4.6L in-front of the airbox? I recently tried to add a pipe into the box going behind the headlight, but did not like how close the filter was to the edge inside so i didnt think the filter would be able to breath properly. Anyone have ideas before the box?
Old Mon, September 12th, 2011, 08:26 AM
You could try joining it to the airbox with a threaded adapter fitting going into the black plastic and connect your front pipe to that. There isn't really enough space to do it with a preformed coupler.
Tags
dwv intake mod
