Old Sat, October 31st, 2009, 11:18 AM
buzzfx4, I just stumbled across a thread containing a problem similar to yours. In his case, he didn't quite have the USB cable inserted fully, either in the PC or the Gryphon. It would power the unit, but the Gryphon would not connect. Make sure you're fully plugged in.
And, another thought. Is your PC a laptop? I have a laptop (an Averatec) that WILL NOT power an external disk drive properly. It spins the drive, but if I try to do a backup to the drive, it cannot read the drive properly during the "verify phase". This is even using a USB cable that has two PC end plugs that are supposed to get more power to the external device. There's nothing wrong with the drive of course, it works just fine with a different laptop or my desktop. Possibly, your PC's power supply through its USB port is just not enough to BOTH power AND communicate with the Gryphon? Any way you could try it on a different PC?
Old Sun, November 8th, 2009, 12:51 AM
buzzfx4 buzzfx4 is offline
Chris
buzzfx4 is on a distinguished road
Ok. So I gave up. After uninstalling and reinstalling Pegasus and trying to manualy install the programer as new hardware with no luck I just said F it and went looking for another computer. I found an old laptop and installed Pegasus on it and everything that goes with it. The programer works like normal with the new computer, no problem what so ever.
So I have no idea what was wrong with first computer. I thought maybe it was the computers 2.0 USB driver got F up but it wasn't. So I don't know.
Thank you every for the help ad the suggestions to fix the problem.
  #23
Old Sun, November 8th, 2009, 06:34 AM
Don't worry about it!
I had to find another computer too!
VISTASUCKS
