Old Tue, January 12th, 2010, 07:02 PM
If they put something down to melt ice that stinks up your truck then you might have a problem when summer comes around. I've smelled what a warm front can do to a bucket of bait.... my eyes still water at just the thought.
Old Tue, January 12th, 2010, 07:26 PM
shotgun's Avatar
shotgun shotgun is offline
Gryphon CTS
Originally Posted by RUSTY2STUFF View Post
Ok on the drive home I noticed the smell is worse when the heat is on and even worse when it is on the floor only. When I got home I smelled the floor mats carpet everything, but no smell. When I took my shoes off I smelled the bottoms and eewwww the smell. I think I may have walked thru something. I will drive it tonight WITH DIFFERENT SHOES and post up when I get home.
I feel STUUUPID . I was out of work most of last week and only wear my work shoes to work which is where my Gryphon was delivered on Monday. It snowed last week and I wonder if something was put down where I work and I walked thru it on my way into work. I installed the Gryphon during my lunch and smelled it for the first time on my way home . If that is it I'm a moron.
Thanks for the waisted brain power.
I'll still post my version after I check them.
If this really is the problem, we need to make this a sticky!
Not laughing at you, just laughing with you and I really hope it's this simple.
  #23
Old Tue, January 12th, 2010, 07:48 PM
X2 what he said!
Made me choke on my coke!
Hehehaha!
  #24
Old Tue, January 12th, 2010, 07:52 PM
Bamboo,
Make sure the PID is set to CHT and not ECT. That 192 sounds more like an ECT.
Its not that I don't believe you but just double check it?
Please.
  #25
Old Tue, January 12th, 2010, 08:10 PM
Originally Posted by bambo2888 View Post
...<snip>...Jack, I have an 04, K&N CAI, and the gryphon on level 2. my CHT didnt get above 192 all night. Does this mean im running rich? shouldnt i be a perfect candidate for extreme lean conditions?
You COULD be a candidate for "lean", but I'm not as sure as 88 is that CHT is really a good indicator. If your load is low (no hills, no high outside temps and no high RPMs, you're not going to see high CHT values. A value of 192 is about what your thermostat is supposed to open at (195 degrees), so it's probably just doing its job. And, Level 2 is a "richer" tune and in gassers, a rich mixture "cools" the engine.
My CHTs tend to stay under 200 (I think) when I'm not towing and just cruising on level ground. If I start climbing, though, they jump to the 210+ region pretty fast. I don't recall seeing anything above 220 though, even on hard tow pulls up mountain passes.
Really though - you WANT the CHT to be in the 195-210 region. This is where the engine operates efficiently and the emissions are lowest.
Old Tue, January 12th, 2010, 09:43 PM
bambo2888's Avatar
bambo2888 bambo2888 is offline
bambo2888 is on a distinguished road
Bamboo,
Please.
Yup, CHT it is.
Fair enough, I guess I'm just suspicious when my truck is working correctly... that doesn't happen to me very often
04 Lariat 5.4 4x4
Gryphon Programmer custom tuned by Bill at PHP ~ 325/60/18 Terra Grapplers ~ K&N Cold Air ~ 2.5 HBS Level ~ Skyjacker Shocks ~ SI/DO Flowmaster 40 w/ deleted rear cats ~ 8000k HID headlights and foglights ~ Blacked out tails ~ Hardwired STI Driver ~ Rockford Fosgate Amp, 10" Sub, w/ Infinity References
BLACKED OUT TAILS FOR SALE!!
  #27
Old Tue, January 12th, 2010, 11:33 PM
RUSTY2STUFF's Avatar
RUSTY2STUFF RUSTY2STUFF is offline
Whopper aka STANK FOOT
RUSTY2STUFF is on a distinguished road
Ok. I'm 90% sure it was the shoes. It's gotta be the shoes.. Please feel free to laugh at me. I am deserving and holy it's funny. I'm glad it was that easy . if it is the shoes. Now I'm gonna have to burn a month old pair of Chaps dress shoes and they were really comfortable, ugh. I'll be wearing a different pair tomorrow so I can be 100% sure. If it is the shoes you guys can pick my avatar. I tried to attach the pictures. Hopefully you can see them. By the way my first name is Donald, so Dumb Donald.
Attachment 355
Attachment 356
Attachment 357
The more I think about it the more it makes sense. After the truck is warm I use the dash and floor heat and right about the time I get to the twisty, hilly part of my drive (more on and off the throttle = more drone) I switch the heat to full blast on my feet, my feet are wearing the stinky shoes, So more drone, more smell and my brain says they go together DOH!!!
So anyway the number stuff. Not that it really matters now.
Firmware 3.02.0639
Calibration 1.02.0644
CHT was pretty steady at 202 and fluctuated between 198 and 206. It went up to a max of 214 about 2 miles when I first left work. I suspect the thermostat was blocking coolant till the engine warmed up.
On my way home I drove between 50mph and 60mph for about 20 miles. Then about an hour later on the highway 20 miles to play cards and 20 back at 65mph to 70mph.
Thanks again everyone,
Gary(for some reason I go by my middle name)
Oh. Can someone try to get this to Corey. She might find it funny and I think a little laugh might be a good thing.
  #28
Old Tue, January 12th, 2010, 11:43 PM
I'm just glad it was your shoes and not your motor!
You had me thinking in overtime! I really don't want to go down ths road again.
Now get the Frebreeze out or the Simple Green and start deoderising!
  #29
Old Tue, January 12th, 2010, 11:48 PM
Lean=to much air not enough fuel
Rich=to much fuel not enough air
Lean burning motors often have hotter exhaust gases and that's why holes get put in pistons, valves seals go, pipes blue, exhaust manifolds crack, and more.
Rich burning motors often have fouled plugs, plugged cats, soot deposites in exhaust, and more.
Been subzero to mid 20's up here and my cht's are still in the 200's on the stock tune!
Maybe one of these days I should get that vista thing and try to update to Bill's adjustments that he did for me?
  #30
Old Wed, January 13th, 2010, 11:15 AM
Hello,
IT WAS THE SHOES, FOR SURE!!!!!
I want to thank everyone again for the time and brain power you spent trying to help me and I’m sorry it was a waste of both.
88 racing I am also very happy it was not my engine!!!!
I wish it were easier to pull the spark plugs on these tanks. Then I could see if it’s running lean.
I have just over 50k miles. I saw the TSB last month when I found this forum and I’m terrified about changing my plugs. It’ll be the first thing I do when I break out the Mustang this spring.
I think I’ll change my screen name to STANK FOOT. Any thoughts on the avatar?
Thanks again
Gary
