Old Thu, June 3rd, 2010, 12:25 PM
Pipe schedules only relate to durability and wear.
It also indicates pipe wall thickness and years of expected use.
I could have a sch10+sch40+sch80 and all 3 could be rated at 300 psi.
Hope this helps?
Originally Posted by LonestarROB View Post
Oh no, they did have PVC just sold out of the size I needed(sans a 10 foot piece). I'll get it at another HD/Lowes.
What is "Sch 40"? I was just looking in the Plumbing department.
Old Thu, June 3rd, 2010, 01:05 PM
Thanks, 88! I knew I should have let you answer that, since it's in "your field".
Old Thu, June 3rd, 2010, 01:27 PM
The wiki definition:
Nominal Pipe Size - Wikipedia, the free encyclopedia
Little bit more in depth.
Old Fri, June 4th, 2010, 01:38 PM
LonestarROB's Avatar
LonestarROB LonestarROB is offline
Lonestar Legend
LonestarROB is on a distinguished road
Will PVC-DWM SCH-40 Foam Core work? If not then I'm screwed because thats all anybody has around here. Nothing in the 3" except foam core.
Old Fri, June 4th, 2010, 01:46 PM
Yeah, I think that will work. Is it only about a 1/4 inch thick? Just make sure that the 3" connector will fit over it. I just checked the scrap I have and it says 3 inch coex cellular core. It looks like it has a super fine foam(an offwhite color) between two thinner white layers.
Old Fri, June 4th, 2010, 02:11 PM
We kinda got off track. If the inside diameter is 3 inches, the material is rigid and it will fit in your connector then it will work. You dont have to use a specific material for this, just something that will work.
Old Fri, June 4th, 2010, 02:25 PM
Lonestar Legend
Sweet! Yea thats what mine says and looks like. Tag on the shelf called it Foam Core. Just wanted to make sure. Time to break out the sander i guess.
Old Fri, June 4th, 2010, 02:27 PM
You dont have to use a sander if you dont want to. I used a regular hack saw to cut a notch then cleaned it up with my pocket knife and it turned out just fine.
http://forum.gopowerhungry.com/34493-post200.html
Old Fri, June 4th, 2010, 03:22 PM
Lonestar Legend
Made a(possible) interesting discovery. This is the piece, that goes into the fender, from the S&B CAI being removed.
It's exactly the right size(obviously) to fit the hole. Couldn't it be made to work and not need the PVC?
Old Fri, June 4th, 2010, 03:24 PM
That will fit into the fender perfectly but the intake might be just a bit too far away to connect. Try it and take some pictures so we can see.
