Old Sun, April 5th, 2009, 02:11 PM
Not the SAME data...but each header alters different aspects of the tuning.
Here's WHERE the "parameters", "maps", and "functions" come from:
Old Fri, April 10th, 2009, 03:45 PM
Talked with Bill last night and he is going to use the 2001 EBM1 DPC-452 VRAA6 base files as he says it has better shifting than the EBM2 or 3 files... Only thing I will need to do is disable the PATS functions... which is fine with me cuz I hate the damn thing..... Only have one matching key anyway which is ziptied to the ign column But he is gonna do that on an initial set of canned tunes so it makes my initial setup and install as easy as possible :thanks: Bill
I guess the EBM 1 2 3 are similar to the PMT 1 2 3's used in the trucks? If I remember the PMT1 is the preferred PCM due to shifting quality right? I would think the shift patterns on the Excursions are different from the F250s due to the max CGVW and that u cannot gooseneck or 5wheel an Excursion. They probably are a bit softer for that SUV effect too
Back after many years.
2003 F250 CC LB 4x4 7.3PSD
Minotaur user.
Old Fri, April 10th, 2009, 06:50 PM
Since the definition files used for each are the same (EBM1/PMT1 are VRAA6 and the EBM2/3 and PMT2/3 are VRAA7) I would assume that the shift characteristics would be very similar.
There are certain aspects of PMT1 that are better. With the way my wife and I drive when unloaded, we would never know a difference. The differences really start to show up when towing (as well as racing...so I hear...but we don't do that). Namely the forced 4-3 downshift TC strategy and the WOT lockup.
Old Fri, April 10th, 2009, 07:48 PM
Question
Yay Just got the MDF and some binaries from Bill. He had to shut down for a bit due to thunderstorms but I got a few questions about the interface and values
is 0=off and 1=on for things like PATS
There are 2 columns in Parameters. is blue the original values for the stock PCM file and blue the modified value or is Blue the stock sett for the specific binary that is loaded, say 100 HP tune
Under functions there are items like FN012, FN013 and so on? what the heck are those??? some explanation please
Minotaur user.
Old Fri, April 10th, 2009, 08:18 PM
I sure wish I could get MY definitions......
The BLACK is the one you are modifying. The BLUE is the one you're comparing to. You'll get a green and red if you load more binaries into the program at once.
Usually, the "FN" values are simply normalizers, scalars, and undefined items. There isn't too much in any of those that you'll even need to be concerned with.
The stuff you NEED is already defined.
Old Fri, April 10th, 2009, 08:51 PM
Oh hence the color code next to the binary file... I should have figured that one out
I know why it didn't click, I had 2 binaries open but they were both the same file heehee
Minotaur user.
