Old Mon, March 2nd, 2009, 11:15 AM
Originally Posted by orygunf150 View Post
Well I was hoping to hear from Bill on this one (I'm sure he is pretty busy) but there is a definate reduction in power. I monitored comm gear while taking off in 2nd gear, after a few seconds shifted to 3rd and it took off like a different truck. Didnt shift to 1st, nor did the tc ever lock. I wonder if it does it in 4WD?
For some reason, I've noticed that the truck will go into a reduced power mode in Manual 2nd Gear. I'm not sure what the purpose of this is other than to prevent burning up the clutches in the transmission by trying to start from a dead stop in 2nd gear. I've never really been concerned about it since this is not a normal driving situation for most folks.
By the way, you can manually recreate the symptoms. Put the truck in 2nd and take off from a stop. At about 30 MPH, matt the gas pedal and after a second or two shift from 2nd to Drive. You'll instantly feel a change in power output. Make sure you're not downshifting when you switch to Drive or it makes the whole test pointless.
  #22
Old Mon, March 2nd, 2009, 03:26 PM
Originally Posted by SinCityFX4 View Post
Good info thanks Jack
That sedona red dirt/mud is alomost worse than beach sand isn't it.:gag::whistle:
The Sedona dirt is almost like red talcum powder! Super, super fine and all over everything. There was a very nice, steep, "sharp-rocked" road out of Sedona called Schnebly Hill Road that we drove up. Beautiful drive at about 5 -10 mph and a great test of tire durability. My understanding is that it was the original route in and out of Sedona. Doesn't look like much has been done to improve it since then.
Bill, I wonder if the reduced power in 2nd is just to minimize slippage on startup in snow or on ice? I do know though that it's a good gear to pull a trailer up a steep grade (7%+) in the mountains.
Old Tue, March 3rd, 2009, 06:59 PM
orygunf150 orygunf150 is offline
Inbred Oregonian
orygunf150 is on a distinguished road
Yes Bill, thats exactly what i'm talking about. Sometimes I drive in the mountains with some short but steep hills where I like to hold it in 2nd gear, but the power is just not there. I was wondering if it is an electronic thing that can be defeated with the programmer.
  #24
Old Wed, March 4th, 2009, 12:52 AM
I'm still looking at that. We know where the throttle tables are but for some reason it doesn't seem to work on the 2nd Gear settings. Fortunately, the Expy does the same thing and as soon as I have a little time I'll be fixing that.
  #25
Old Wed, March 4th, 2009, 06:17 PM
Inbred Oregonian
1st and 2nd gear positions cause the PCM to remap the throttle
essentially the throttle gets cut in 1/2 by placing the shift lever into 1st or 2nd. the throttle then is more "sensitive" and you have better control of the wheels.
this is achieved because you now have full pedal travel to control only 50% of your normal throttle...so you don't inadvertently spin the tires by giving it too much gas
it's a little known feature to help you control low speed situations. like boat ramps, towing heavy loads, 4x4 offroad
This is a response from Tylus on the FTE forum regarding the same issue, if it is the pcm remapping the throttle I would think it could be programmed to not do it. Or, perhaps there is a microswitch somewhere that can be bypassed. What do you think Bill?
  #26
Old Thu, March 5th, 2009, 11:29 AM
That's exactly what it's doing and I do know where the map is. The problem is that when we change it to improve the range, it often (read that as nearly always) sets a Throttle Control DTC. That's what I'm trying to work around.
  #27
Old Thu, March 5th, 2009, 12:40 PM
Shouldn't this be "less sensitive"? (But I'm not trying to split hairs here, just trying to understand this). Effectively then, placing the shifter in 2nd (or even 1st) DOES make the truck less likely to spin tires on startup in a slippery situation.
But now, I've got another problem. From Tylus' explanation, it would seem that you are very limited in total power output if you have locked the transmission in 2nd. As I said in a previous post, that doesn't seem to be my experience, at least not when I'm towing my trailer up a 7% grade in the Colorado Rockies and passing every other RV and semi in sight (since I can maintain 65 mph and they can't). I lock it in 2nd to keep it from shifting back and forth between 2nd and 3rd in this situation which it will do on grades like this. This technique even seems to work on very "twisty" steep roads where the maximum speed is about 25 mph. I have no problem whatsoever getting everything moving from dead slow (around a severe switchback) while in 2nd gear. On shallower grades, of course, I can just lock the overdrive out to keep from cycling between 3rd and 4th.
I guess what I'm trying to ask in all this is: If my total throttle input is cut in half, where the heck am I getting all this power from? Is it Bill's fabulous tune?
Old Thu, March 5th, 2009, 01:18 PM
I've thought about this some more, and maybe it works like this?
If we assume the change in Throttle Position (TP) vs Pedal Position (PP) is nearly 1:1 (linear) when the gearshift is in Drive, then possibly the change in TP vs PP is more parabolic with the shifter in 2nd or 1st? In other words, possibly TP reaches the same maximum point in the lower gears, but it does it more slowly at first?
Thinking about it, that's the way I would have designed the relationship, because there's no reason I can think of to limit the max TP.
(And I know the Drive TP vs PP doesn't have to be linear, I just used that as a base for comparison).
Old Thu, March 5th, 2009, 01:40 PM
Why mess with it? Someone along the lines must have thought it was important for something.
Good example Jack of mountainous driving.
Okay what if we get it changed and then one day we need it the way it was designed? Are we going to sit there and reprogram it while in potentially dangerous situation?
Just a thought
  #30
Old Thu, March 5th, 2009, 02:33 PM
Inbred Oregonian
Thanks for looking into it Bill, let us know if you find anything out.
Jack... maybe the power is there in the upper rpm range allowing you to pull the hills, and the power reduction happens in the lower rpm range which is where you would be in a slippery condition. Just a thought. It seems as though Ford would have made this feature optional, (it's there if you need it).
