Old Sun, February 14th, 2010, 02:40 PM
Originally Posted by F150 Man 4Eva View Post
Wow, this is getting pretty technical. Is there any definitive answer to the question, is my K&N setup helping or hurting me? And after all of this, I am assuming that getting lower MPGs on my custom perf. based against the canned tow tune isnt alarming.?.? Thanks again
The K&N setup isn't exactly hurting you but to eliminate the CAI drone Bill has to go to a stock cam advance curve which isn't as good for performance. I would expect that the tow program would have modified cam curves for more performance while also having a richer fuel map to help on towing. With a CAI you usually have to use the richer tow program to keep from running a lean engine. The stock cam settings may be what are lowering mpg.
I also remember that you are running big tires. They are effecting the spark timing by effecting the RPMs.
As Bill said earlier when the RPM is low the engine load goes up resulting in the spark timing getting dropped to lower the chance of detonation. By lowering the timing you also lower both performance and efficiency. If the truck isn't regeared then your timing is getting thrown off because the RPM's aren't high enough. Also since you are slinging around more rubber the load goes even higher, dropping the spark timing even more.
Old Sun, February 14th, 2010, 07:43 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch is on a distinguished road
Well said Colby.. so to put it very basic, you want the drone of the CAI gone so Bill pulls it down to stock cam settings, thus lowering power and MPG. the timing drops at lower RPMs in order to prevent detonation during certain loads. now you have larger tires thus compounding the effect of those loads and helping to create your worse MPG.
Try playing around with different RPM levels and calculate your MPG on paper, not computer.
And colby, you don't have jack that is messing with your aerodynamics. your bumper might weight 100lbs and your antenna ain't jack. heck my antennas that i used were much more than yours is, yet no difference in any mileage or anything and my truck already has the aerodynamics of a brick... haha. then again, it is a diesel, not a 4.6. LoL
Travis-- Death Row Diesel Inmate #7
1995 Ford F-250 regular cab long bed PSD
MODS- 6637, TE modded 17*, Rosewood 160/80's, Tony's tunes, HPX, 120v IDM, 3" DP to 5" stacks, CPR fuel system, DRD traction bars, ISSPRO EV2's, scan guage, VALAIR full ceramic clutch, Midwest short throw shift kit
381hp/870tq
14.32 @ 97mph
  #23
Old Sun, February 14th, 2010, 07:48 PM
Jack,
Keep in mind that I am referring to camshaft timing, not spark timing. The spark curves don't change when running a CAI.
OK, so we're talking valve opening and closing times. Thanks for clarifying that, Bill. Forget EVERYTHING I posted in my last post, since I was thinking spark timing. I'm sure the valve timing has a somewhat similar effect, but nothing like what I was thinking.
Old Sun, February 14th, 2010, 08:05 PM
F150 Man 4Eva, if you want to try what tatsch said you can go in and adjust your 4th gear shift and lock points. Raising them will usually hurt your mileage and lowering them will do the same on performance until you get the RPMs back up, but every truck is different.
Old Mon, February 15th, 2010, 05:07 PM
Hidden Valley
Naa, I don't really want to go in and fool with anything right now. It isn't like it's a problem..just something to get used to I guess. My AVG on Gryphon says 13.6 right now and trucks comp. says 12.6. I am gonna give it some more time and see what happens. But I do tend to keep my eye on that INST ECON. and it isn't pretty. Oh well I guess. Let me ask this though. Does the drone sound indicate running lean or can they exist seperatly? I definitely want my truck running like it should, but at the same time...if taking away the loud sound is hurting my MPG...I would say bring the drone back. It never really bothered me anyway..I kindof like hearing the power when I hit the gas. But is that drone only there because the truck is running lean and/or not as it should?
  #26
Old Mon, February 15th, 2010, 06:57 PM
The drone is only a harmonic vibration, like blowing across the top of a bottle. The big thing on the side of the stock intake is a resonator that takes that sound out for that particular setup. The reason Bill tunes out the drone is because after a while people get tired of it and then ask him to take it out.
Old Mon, February 15th, 2010, 11:31 PM
On the stock intake those chambers are called hem-holz silencers.
For give me if I spelled the name wrong but I'm close.
  #28
Old Tue, February 16th, 2010, 10:43 AM
I was going to say the name too but I couldn't remember how to spell it either.
Old Tue, February 16th, 2010, 11:48 AM
Helmholtz! Sheesh!
Here's a Wikipedia article on it: Helmholtz resonance - Wikipedia, the free encyclopedia
Note near the bottom it talks about reducing drag on aircraft bu 40% using acoustic liners based on the Helmholtz principle. This effect was something I was a bit concerned about when people talked about removing the resonators from intakes. I thought it might induce standing waves in the intake that would hurt its efficiency. I think that is why "drone" is probably NOT a good thing too.
Old Tue, February 16th, 2010, 11:52 AM
Thanks Jack!
I was close but no cigar!!!!!!
