Old Fri, June 1st, 2012, 06:00 PM
Lilpooh Lilpooh is offline
Lilpooh is on a distinguished road
Default Time for another Gryphon
What he wants to know is, if he does have a functioning MAF, is there a way to trick the PCM into thinking that the EGR has not been tampered with.
The answer is no, there is no way to trick it without a custom tune or modified stock tune to stop the ECM setting off a EGR code.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ,QT,GH,ID,head studs,II Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,Snow Perf stage II,EGR delete,AD2,4" turbo back straight pipe,K&N intake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod
Old Mon, June 4th, 2012, 07:18 AM
Rheatherly's Avatar
Rheatherly Rheatherly is offline
Rheatherly is on a distinguished road
If this truck has a MAF sensor, other than a custom tune is there a way to avoid the CEL coming on?
2005 F350 6.0L 6 speed FX4
K&N CAI, Evolution CS
2000 Ford Explorer
1984 Bronco
351 windsor
To many to list
1968 Galaxie
Old Mon, June 4th, 2012, 08:48 AM
No, you will need a custom tune or a modified stock tune.
Old Mon, June 4th, 2012, 08:53 AM
Rheatherly's Avatar
I may just get a Gryphon CS for now, get the FICM Atlas 40 later as funds replenish.
2000 Ford Explorer
1984 Bronco
351 windsor
To many to list
1968 Galaxie
Old Sun, July 29th, 2012, 06:50 PM
Lowenbrau Lowenbrau is offline
Lowenbrau
Lowenbrau is on a distinguished road
I would start out with the studs. . . Any significant change to horsepower is going to put you on the fast track to head studs anyhow. . . All the damage they cause, is the expensive part. Assuming you running the 6.0L. . . .
