Old Tue, January 27th, 2009, 12:33 AM
We've been doing the "Gotts" mod on the 04+ since they came out and have had no adverse effects whatsoever. AFR is not significantly affected.
Old Tue, January 27th, 2009, 10:42 AM
Originally Posted by Mark_123 View Post
Here's something interesting too. I took the intake tube off, and sure enough the snorkel is only 2" wide into the fender. I also noticed 6 small holes drilled into the intake tube near the snorkel. Each Helmholtz resonator had a hole drilled in the bottom as well. I'm guessing this is to assist in airflow at WOT????? I bet this is where the occasional air intake whistle comes from when starting in cold weather. The holes would seem to defeat the purpose of bringing in cold air from the fender. Hmmmmm.......
Mark, I think the holes in the resonators act a bit like "shock absorbers" to dampen out the "springyness" of the air inside. It's possibly like the tuned port in a base reflex speaker enclosure.
As far as the 6 holes in the bottom of the intake, these don't make sense to me at all. We used to see a flapper door in the intake that would pull air off the exhaust manifold during cold weather to aid in cold weather starting and running, but it would close when the engine got warm. These things are always open though. You could be right about them allowing additional air in during WOT at high RPM, but it seems like an odd way to do it. Actually, the Bernoulli effect means that regardless of throttle position, air is ALWAYS being pulled in through these holes and mixed with the air coming from the fender well. Their position is not really over anything "hot" though. I wonder if they are part of the silencer system?
I've never heard the "intake whistle", but we don't get very cold here.
I'm tempted to tape over the holes with aluminum tape to see what happens.
Old Tue, January 27th, 2009, 12:38 PM
I think you're spot-on there... Instead of amplifying the offending frequencies, it helps dampen them.
Old Wed, February 4th, 2009, 08:26 PM
KIRT KIRT is offline
KIRT is on a distinguished road
I was wondering what kind of experiences Bill or any others have had with the volant cai?
2007 F150 XLT 5.4L: 3" SISO MAG: VOLANT CAI: GRYPHON TUNER
Old Mon, February 9th, 2009, 02:16 PM
Okay for anyone looking to do an upgrade to their air intake try looking at tru-flo sealed system. It retains stock air box and gets rid of that plastic intake tube, then is replaced with a powder coated tube over to the fender. So you can use any stock filter replacement that you desire or the one it comes with. Just a thought for some of us out there whose parts bins are empty.
-Lars
Old Mon, February 9th, 2009, 07:25 PM
-Lars
And, Lars, it sounds like this does not alter the stock MAF sensor enclosure in any way? I'm puzzled now that it would make your engine run poorly.
Old Tue, February 10th, 2009, 12:37 AM
Default MAF sensor location
Jack,
From what I have seen in some of these installs and test drives. It is no different then the stock system except the restrictive intake tube is done away with and a different stock size filter is used. If I was following Bill's description of the "gotts" system correctly or in that system is the MAF sensor relocated also. Another thing that is note worthy is very little to no droning noise. 4.2 and 4.6 have something different in their stock intakes over the 5.4 looked like a restrictive cone shaped funnel insert. Found that in a 05 4.6 STX and forgot what year 4.2
-Lars
By the way Jack great job on the snorkle tube post!!!
Loved the pictures!
For $13?
That is kind of what I meant when I said sometimes our parts bins are empty. There are some of us at sometimes in our lives that the packaged product looks like the shure thing, but if we put our mind to it like you did we can take pride in a job well done.
Last edited by 88Racing; Tue, February 10th, 2009 at 01:06 AM. Reason: Reading another thread of Jacks
Old Fri, February 13th, 2009, 09:11 PM
coggerwayne coggerwayne is offline
Stuck in a snow drift
coggerwayne is on a distinguished road
K&N
I got the K&N - works OK - only loud when I stomp on the gas otherwise no drone louder than the MBRP mufflers.
Only complaint is the fit between the box and hood - seems to me designed to seal between the top of filter box and hood but it like its not tall enough.
Old Wed, February 18th, 2009, 10:52 AM
austinrhea austinrhea is offline
austinrhea is on a distinguished road
Has anyone tried the tru-flow system? I found them for around $130 and they look like they accomplish the same as thing the modified factory intake.
Old Wed, February 18th, 2009, 05:12 PM
Jack,
-Lars
Loved the pictures!
For $13?
Actually, Lars, the real cost is on the order of $8.00 now. It was $6 and some change for the ABS tube and you can buy 3" hose clamps for 99 cents. So, since I didn't use the coupler in the final product, I don't count its cost.
The MAF sensor's environment is not altered in any way in my truck. It sits up above the filter box very near the throttle body and, as you can see, all the modifications took place about two feet from it. I know the filter housing design is completely different on pre-2004 trucks though, so the MAF sensor location might be different too.
I took my truck out for a bit of a spin today because I installed pressure monitoring transmitters on my valve stems. I wanted to see if they upset the tire balance. (They didn't). But, I stepped on the gas pretty hard a couple of times and there's no drone.
