Towing
Old Wed, July 8th, 2009, 09:16 PM
Originally Posted by 408F150 View Post
Second, you are going to want either Super Springs or air bags to keep your a$$ from dragging. Super springs run about $375 a set and take about an hour to install (they add 2,000# of spring to help keep your leaf springs from getting over stressed), airbags are I think a tad more.
I agree with everything in your excellent post except this one statement.
The whole point of a weight distributing/load leveling hitch is to transfer the trailer tongue weight to the four wheels of the tow vehicle, without overloading either of the axles. Putting heavy duty suspension components on the rear of the truck will keep if from sagging, so much so that the load leveling hitch will make the truck look fine, even though the rear axle is supporting way too much load. You CAN overstress the rear axle of the Tow Vehicle (TV) this way.
If you look at the instructions for any of the load leveling hitches, they say, "Do not use airbags, springs, etc to compensate for the hitch load".
The hitch itself transfers the load toward the front of the TV so that the weight on both axles is almost equal.
The weight distributing hitch will keep the rear springs of the TV from being overloaded.
And, as you mentioned, I think anti-sway control is good to have too, even if you do make sure the hitch load is 12-15% of the trailer weight (a must).
Old Thu, July 9th, 2009, 12:30 AM
Sburn Sburn is offline
First, I'd recommend installing two 5" electric fans on your transmission cooler, you can either set them up to turn on at a certain temp or run a basic +/- wire setup to the cab and flip them on once you hit 180* on your Gryphons ATF temp gauge.
Agreed, trans cooler fans would be a good choice.
FYI, there's two different sizes of factory trans coolers:
The smaller of the two came with the lighter duty towing package and has about 4 or 5 rows of cooling fins. Factory light duty towing packages have a flat-4 only trailer connector on the rear bumper.
The heavier duty option has a cooler with 8-10 rows of cooling fins and is matched with the dual 7-pin + flat-4 combo trailer connector on the rear bumper.
The heavy-duty (AKA "Super Cooling") was an option on most trim levels and may have been standard on the higher (Lariat/KR) levles.
Upgrading to the larger cooler, if you have the small one, is a simple bolt-on change and the part is about $100 from Tasca Ford Parts or the like.
Old Sun, July 12th, 2009, 07:02 AM
TXWolf's Avatar
TXWolf TXWolf is offline
Native American Redneck
TXWolf is on a distinguished road
We picked up the travel trailer from the dealer last night, and WHOA!, is it big! LOL I have a few hesitations about it, though.
First off ... my back end of the truck sagged big time. This was expected to some degree, but it makes the truck look really weird. I'm thinking about adding Superleaf Springs to help with the aesthetics.
Second ... I'm new to using an electronic brake, and I'm having a heck of a time adjusting them. They'll act fine one minute, but then the next time that I go to slow down or stop, they feel totally different. As I drove into the neighborhood, my wife says that the tires and axles "bounced" really bad as I was braking. That has me a bit worried about the long-haul effects to the trailer.
Lastly (for now) .... Keeping an eye on the Gryphon gauges .... CHT never went above 220 .... CFT never went about 210 .... but the TFT hit around 219 a couple of times (pulling up a couple of inclines). With the towing package, I have a transmission cooler on my truck, but I'm guessing I might need more of a heavy-duty one?
Except for my worries with the TFT, the truck pulled the trailer just fine. I definitely knows it's back there, though! I'm going to take it to one of our high school parking lots today, and practice backing up with it, and getting the electronic brakes adjust better. And then I'll take it to the RV storage, until it's time to take it to the coast.
http://dygytalworld.ehost-services139.com/forums/image.php?
2008 F150 Supercrew Lariat 4x4
5.4L - 4.88 Gears
PHP Gryphon Programmer - BDS 6" Lift - Magnaflow Dual Exhaust - JLT Ram Air Intake - 20" Pacer Ridgeline Rims with 35" Mickey Thompson Baja ATZs Tires - Westin BullBar with Driving Lights
Old Sun, July 12th, 2009, 08:37 AM
Boy, I don't like it that you say the back of your truck sags. It shouldn't - period, if the load leveling hitch is set up properly. And, if following the instructions in setting up the hitch can't correct the sag, you need a higher capacity hitch, not springs.
Electric brakes ARE somewhat tricky to set up. Ideally, you want it so that you don't feel the trailer either pushing you or pulling back on you when you brake. In other words, for the most part, the trailer brakes stop the trailer and the truck brakes stop the truck. It won't be quite that "perfect", but you should be able to get it close. At about 25 mph on level ground, you want to be able to manually apply the electric brakes only (push the button on the controller) and not have the trailer wheels skid.
The CHT sounds fine. The TFT is worrisome though. I think they DO make higher capacity transmission coolers, possibly with their own fans. Regardless, you're going to have to change the fluid more frequently. If the TFT never goes above 219, yu're probably ok with your current setup.
When you climb hills, try to keep the transmission from shifting. This means dropping it into 2nd or even 1st, so that it's locked in gear. And, unless you're going dowhill, overdrive is probably something you won't be using, but again, let the transmission tell you what to do. If you feel the TC unlocking and locking a lot or if it's constantly down and upshifting, then lock out the O/D.
Have fun!
Old Mon, July 13th, 2009, 12:28 AM
408F150 408F150 is offline
408F150 is on a distinguished road
Even with my WD hitch the Super Springs do help. They are NOT load bearing springs when I use them, I just use them as extra support in extremely bumpy areas. I have them set to one of the more mild bracket positions so they basically keep my shocks from over compressing on bumps (I pull my trailer into the dunes at Pismo and it's not uncommon to blow the valves in your shocks from the trailer jumping around). My trailer before I had the springs would fully compress my suspension (This is with a Reese WD hitch rated for 800#) and leave no travel on the springs or shocks. Now I pair Blistein Heavy Duty shocks with my springs and they work great.
Troyer makes a good stacked-fin trans fluid cooler with an automatic thermostat controlled fan. I have one but am yet to install it because the plumbing intimidates me. I can wire stuff all day, ATF lines I'm not super confident with. The only way to help you trans temp besides what was already mentioned is a deeper trans fluid pan so the fluid has more time to "rest" before its recirculated. I've heard the transmission coolers from the V10 SuperDutys are direct bolt-ons. They're much larger but still don't have a fan, so I'd add as big of one as you can get away with.
If your trailer starts bucking your truck around like a see-saw, it could be one of a few things. If you're under-breaking the trailer, it's basically running into your truck when you stop, which shoves your a$$ end down rocks the truck around on it's suspension. If you over-break the trailer, it puts a lot of rearward tension on the hitch and when you release the breaks all that inertia is unloaded forward onto your truck. The final thing that makes them act squirrely when breaking is water in your tank. 800+# of water sloshing around, especially when going downhill, has literally pushed my truck in pulses as it sloshed as I went down a wet hill, if it weren't for ABS and 12" wide tires it coulda been bad.
There should be a brake calibration dial on your controller, the easiest way to dial it in is gradually increase the setting until the trailer stops dipping your rear end as you stop. At that point your truck and trailer are breaking at the same rare and stopping at the same time. Just remember to use Boost or a comparable setting on the freeway or it will sway under moderate to heavy breaking.
This big of a trailer is always going to be a lot to handle behind a "small" truck.
Old Mon, July 13th, 2009, 08:43 AM
TXWolf's Avatar
I drove the truck & trailer a couple of miles away to a highschool parking lot to readjust the brakes, and noticed that the temps that I am monitoring were all showing to be in acceptable ranges. In fact, the TFT stayed around 196. But then I noticed that I still had the Gryphon set to 87 Custom Performance Tune. So I changed it over to the 87 Custom Towing tune, and the temps all shot up a bit. Now the TFT was showing 212. Not sure why there was such a big variance in the temp readings, going from one tune to another.
Anyhow, I was able to fine-tune the electronic brakes to where it felt like the trailer and truck were both braking well. No more "bouncing" axles, and it never felt like the trailer tires were locking up. I was also able to back the trailer up pretty well, which is something that I was worried about.
I've ordered some Superleaf Springs, to help with the "sagging butt" backend of my truck when the trailer is hooked up. I'm hoping that it helps out a lot. I'm going to call the shop that installed my liftkit this morning, to see what they recommend.
5.4L - 4.88 Gears
Old Mon, July 13th, 2009, 10:27 AM
Since you have a lift the shop is most likely going to recommend airbags from what I've noticed in the past. They work just as well, just might cost a tad more.
Old Mon, July 13th, 2009, 10:48 AM
If your Torque Converter is unlocked, you are going to get higher TFT readings than you will with it locked. If the higher readings were observed during your "playing" at the parking lot, I'd say this was normal. You're spending a lot of time in low gears with the transmission doing quit a bit of shifting. This is more stressful than a "cruise" condition to the parking lot. And, it will take a bit of time for the TFT to come up if you start out with a cold truck.
When I had my smaller truck, I could see the engine temp really go up quickly if I spent any time mucking around in low gears doing any "backing and forthing". Since there's little forward speed, there's nothing except the radiator fan to cool things off.
Old Mon, July 13th, 2009, 01:20 PM
TXWolf's Avatar
That makes sense ... I'm glad I have you guys on here to point out the obvious for me! I've been so nervous about this whole thing that my brain seems to want to shut down at the most inopportune moments!
5.4L - 4.88 Gears
Old Mon, July 13th, 2009, 02:57 PM
Glad to be of help! I'm still concerned that your hitch is not set up right though. Many RV dealerships don't really know what they're doing according to posts on several threads I've looked at.
I think the hitch ball height adjustment is pretty standard, so here's what mine says:
You need to know your loaded trailer's tongue weight to begin with. If you have a 7500-8000# trailer, the tongue weight should be about 900-1200#. I would classify the truck as having "average" springs, so the difference between the height of your ball on flat ground and the inside height of your trailer hitch with the trailer sitting parallel to the ground should be from 1 11/16 - 2 1/4 inches (the ball is that much higher). Then, the equalizing arms and chains should be able to be adjusted so that the compression at the rear of the truck is equal to or maybe just a small amount more than the compression at the front. (In other words the truck rides "level"). (Measure from the ground through the center of the wheel to the top of the fender opening). The instructions for my hitch say if you can't get this, you need a heavier hitch.
They should have given you a copy of the hitch instructions. I'd study them carefully!
