Old Fri, January 30th, 2009, 05:47 PM
kd4crs's Avatar
kd4crs kd4crs is offline
Not a Whopper
The DWV intake mod requires no sanding or fitting. I can email you the instructions if you like. Bill is going to post them on here soon. Mark_123 check your PMs.
EDIT to add: See post #71 in this thread for the DWV intake mod instructions.
Old Fri, January 30th, 2009, 07:10 PM
Originally Posted by Extreme Justice View Post
So Bill what your saying is that we wouldn't have to get NEW TUNES for this Mod? Not like we would if we bought a CAI off the shelf.
That is EXACTLY what he said - and the only reason I tried this mod myself!
Old Tue, February 3rd, 2009, 07:30 PM
Other than the "sexy" look of the commercial CAIs, I wonder why anyone would want them? Trust me though, I wouldn't have tried making one myself if I hadn't read Bill's thoughts on this!
Even though I love to argue obscure points, I recognize Bill's expertise in this area and I know, "I can take it to the bank".
Thanks again, Bill and Corey, for creating a forum that so far, allows us to "think out loud" and not be afraid of sounding stupid!
Old Tue, February 3rd, 2009, 11:37 PM
kokopellimotorsports's Avatar
addicted
Yes, thank you Bill and Corey for the forum.
2001 Dodge Cummins
Tuning is addicting. Lol.
Old Wed, February 4th, 2009, 02:36 AM
glockwinger's Avatar
glockwinger glockwinger is offline
Glocks and Goldwings
glockwinger is on a distinguished road
Well, when I was once dumb and impressionable ...someone sold me on the idea of doing a few mods to my truck. I wouldn't do most of them again, the CAI for starters. Just wasted my money. I wish I had the info then that I have now...it would have saved me and
"All that is required for evil to prevail is for good men to do nothing" - Edmund Burke
Old Wed, February 4th, 2009, 06:18 PM
Mark_123 Mark_123 is offline
Mark_123 is on a distinguished road
So I found this 12" piece of 3" black rubber-coated flexible PVC used for fish ponds (that was a mouthfull) Anyway, I removed the snorkel, inserted the 3" pipe into the intake, then inserted the other end through the first fender wall hole and into the second fender hole. I heated the end of the pipe in hot water to make it more pliable before pushing it into the fender. I then used a black worm clamp to seal the 3" pipe in the intake leading to the engine. Overall....I'm impressed!
I had the snorkel off for a few days just letting it breath the engine bay air. The intake air temp (IAT) seemed to always be at least 10 degrees higher than ambient temp while driving. Of course, if the truck was stopped at a red light, the IAT may go to 30-50 degrees higher than outside air temp (OAT). So now with the little extension added on, the IAT=OAT while driving. Pretty cool if you ask me. I can post photos when the snow melts and the temp climbs back up (currently 20 F). Thanks to all for your ideas and pics!!!
Mark
Old Wed, February 4th, 2009, 07:17 PM
It's incredible how the ideas have taken off here. I think something flexible will probably work better than the "stiff" tube, since the "bend" to match the angle of the stock intake can be more gradual. This should probably produce a slightly smoother airflow, which should cut down on resistance (internal drag) a bit.
I'll be interested in your pictures, Mark. Can you remember where you got this tube? I was looking at the flexible metal tubing like Agent Orange used in his version at Ace hardware the other day. It'll certainly smooth out the bend too.
And, on the subject of air temperature - Here in Arizona, we regularly hit 105+ in the summer. We don't need one extra degree of heat from the engine into the intake when it's like that!
Old Wed, February 4th, 2009, 10:36 PM
Jack, got the pipe on Ebay. Oh, and I thought this was interesting. If anyone tries to make there own mods, I would leave the bellows (rubber looking flexible piece of intake from factory) in the setup. Here's why:
The rubber PVC pipe I pushed into the fender is pretty much stuck in place...it's not going to move. The other end is in the bellows section. As I was revving the engine to make myself think this mod was the coolest thing on Earth, I noticed that as the engine revved and pulled to the opposite side of the fender intake, the bellows stretched to keep from pulling loose any other piece of the intake. I would imagine that any modified intake without this bellows piece might pull the intake away from the fender hole or even damage the modified intake. Just some food for thought.
Old Wed, February 4th, 2009, 10:45 PM
Mark! What a great observation, and, thank you for posting it! I never thought of the movement of the engine under revs. I agree - the bellows needs to stay there.
Old Wed, February 4th, 2009, 11:02 PM
kd4crs's Avatar
Not a Whopper
That is one reason I designed the DWV intake mod to utilize the flex section. Another reason was to absorb/reduce vibration being transmitted from the intake into the fender structure. It also helps the mod be more of a sleeper/stealth mod. I love the fact that I have taken the truck in for service several times and the dealership techs have yet to spot it.
Tags
dwv intake mod
