Old Sun, January 30th, 2011, 10:25 PM
Originally Posted by epowers777 View Post
Dave is this the actual idm plug or the engine harness plug for pin 23 and 24 correct?
And the other pins you unplug the under valve cover harness?
This is with the IDM disconnected and everything else attached, testing from the IDM connector.
Thanks Dave. What do you think about my findings with the scanner?
It is really hard to say about the CCT faults, with aftermarket injectors I would not put a lot of faith in the test.
How many times did you run the CCT....was it consistently flagging the same cylinders?
Old Mon, January 31st, 2011, 12:26 AM
He ran it like 8 times yes it flagged the same cylinders . He told me the same thing that they aren't that accurate so he ran it a bunch of times. He was thinking those cylinders shared the same coil or something in the idm.
I was reading about the injectors that if you take the top cover of the injector there's a plate you remove and under the plate there's a nut and if they become loose you get ruff idled and will fail that test. Do you think they are loose since there brand new injectors?
Old Tue, February 8th, 2011, 08:38 PM
ok I ohmed my IDM harness. everything was within 3.0 and 3.3 except Pin 22 it read 95.4 ohms. So Im guessing i got a crack so im hunting for it.
Old Wed, February 9th, 2011, 09:34 PM
Ok my Harness tested bad So does that mean i need a new harness or is the injector bad?
Old Wed, February 9th, 2011, 09:52 PM
The only way to know is to try and figure out where your extra resistance is, could be a bad injector solenoid, UVCH/ or connector, bad connection or pushed out pin in the main engine harness connector, or a break/ corrosion in that one wire(white/pin 22).
I would ohm out that injector circuit right at the cover gasket and see if it is on that side of the harness before going any further.
Old Thu, February 10th, 2011, 04:41 AM
Dave I want to apologize for my bad typing. The under the valve cover harness tested bad.
So just get a new under the valve cover harness? Just a reminder the pop test came back good all injectors popped strong. All the pins tested good except the 22 pin (white wire) on the uvch.
