Old Tue, June 30th, 2009, 02:41 PM
th3godf4th3r th3godf4th3r is offline
th3godf4th3r is on a distinguished road
well i got the driver side one. it comes on when i show 200 CHT on my gryphon, i was then wanting the second one to come on at 210 CHT. however, i can turn the dial all the way around and it never turns on. the only time it turns on is when i press the a/c button which it should because i have it come on whenever i have the a/c turned on.
its just if the CHT got above 210 the second fan wont turn on unless the a/c gets turned on
thats what is puzzling me
2008 White Ford F-150 Lariat Supercrew 4x4 | PHP Gryphon w/ Custom Tunes | 18" XD Monster's | 33" BFG A/T | AS Leveling Kit | Brandmotion iPod Adapter | 6000k H.I.D Lights | Line-X Bedliner | Weathertech Floorliners| True Dual Magnaflow Exhaust| K&N Cold Air Intake| Troyer Performance UD Pulleys
  #52
Old Tue, June 30th, 2009, 06:46 PM
Desert Racer Desert Racer is offline
Desert Racer is on a distinguished road
well think you might have a problem if you can turn the screw a full 360 degree it is only supposed to go 3/4 of a full turn. think that might be your problem as you may have stripped that lil screw for the controller. that is werid as when my truck hits a certain temp both fans kick on. i see what you are saying. only thing i can think of is double check the wiring. and make sure all connections are good and solid.
2007 Supercab few mods here and there
  #53
Old Mon, July 6th, 2009, 06:03 PM
ok so ive been playing around with it for awhile now TRYING to get the first fan to come on at 200 CHT but it never seems too until about 208-210
the second one i still cant get to come on at a higher temp.
i had guys on f150online tell me to go by the ECT because the t-stat opens at 195 and when i set the fan at 200 for the CHT the ECT is always at about 194.
should i change it so i try and get the fan to come on at 200 ECT??
also the temperature probes, could they be doing this? one of them is a little bit loose but only if you pull it. the other one is better
