Old Thu, February 5th, 2009, 05:45 PM
Mark_123 Mark_123 is offline
Mark_123 is on a distinguished road
Well, here's mine. Be sure to ignore the dirty engine bay. As soon as Winter leaves us I can clean the salt out of my truck
Old Thu, February 5th, 2009, 06:00 PM
kd4crs's Avatar
kd4crs kd4crs is offline
Not a Whopper
Looks good!
Old Thu, February 5th, 2009, 07:14 PM
Looks VERY good! Mark, where did you find the black clamp? And, I went looking for something like the pipe you used at Home Depot today, but had no luck. I wonder if I might find it at a pool supply store?
(And, now I don't feel so bad about my original pictures with the dirty fender wall. I'm extremely nervous about trying to wash the engine bay. I've read too many horror stories over on the f150 forum about wet COPs. Usually, I'd be spraying the entire engine with Simple Green and then hitting it with a high pressure hose. I've even used a pressure washer on the engine in my Honda with no ill effects).
To continue this hijack - my technique for cleaning the built up dust out of my desktop computers is to take the box out on the back patio, open it and then blow it out with my yard blower. Works like a charm!
Sorry for the hijack - it's the way my simple little mind works. :o
Old Thu, February 5th, 2009, 10:38 PM
Hey Jack, I think I only paid $5 plus shipping for the small piece of pipe from Ebay. The black clamp...well, I like to bass fish. I just put a new trolling motor on my Ranger boat last year, so I sprayed a couple of different sizes of clamps to use on my trolling motor sonar attachment. Anyway, this one was left over. I think I just used some $1 flat spray paint I found a Lowes. I have this little OCD issue that always makes me do things perfectly Oh yeah, the dirty engine bay is driving me crazy!!!!
Old Thu, February 5th, 2009, 11:11 PM
So, duh!, you spray painted it! Gollee-dang! What an amazing idea!
So, I troll for "fishpond pipe" on ebay? (That's almost a pun, isn't it)? Maybe tomorrow. Seems like this stuff should be available locally.
But, the horror stories about people washing their engines really makes me nervous!
Old Fri, February 6th, 2009, 12:49 AM
When washing engines, it's not like the small block Fords and Chevys of yester-decade. There used to be very little space for water to collect and where it did, it was harmless.
Nowadays, you got spark plugs that slip down into 8" tubes and the only thing keeping water out is the crappy boot on the COP. Not an impressive setup even in the best of conditions. Any moisture trapped in there will only accelerate oxidation of the plug body which only goes to exaggerate the "broken plug" issue.
I don't really see a problem with cleaning the engine compartment as long as you use low pressure water and stay completely away from the top of the engine. Using any sort of pressure washer is asking for an $800 tune-up.
Old Fri, February 6th, 2009, 01:06 AM
bbbxcursion bbbxcursion is offline
bbbxcursion is on a distinguished road
Whenever I clean the newer fords, I have to pull the coils out to blow that water out of the whole. PITA!
2000 Black Excursion, Two 400hp 7.3 blocks with windows
Old Fri, February 6th, 2009, 08:12 AM
Cajun's Avatar
Cajun Cajun is offline
Takin the low road.....
Cajun is on a distinguished road
A dirty engine compartment drives me nuts too. In fact I was going to take it to the car wash this weekend and get rid of the road salt we had this week. So if I understand right, all I should do with my '08 is a little Simple Green and the regular hose and only below the level of the heads, then use my compressor to blow as much of the water out as possible, right?
^^^ That's my dog Pete, he's a good dog.....
QueenCityBashers.com
South Central NC RC Bashers
Old Fri, February 6th, 2009, 10:40 AM
That might work fine Cajun - I also remember, now that I think about it, that somebody else in the f150 forums recommended using a yard blower (like I do to clean PCs) to blow the plug wells out and dry things off.
Another cleaning product I remember now that someone uses is "Spray-n-Wash" (the stuff you spray on clothes before you put them in the washer to get rid of stains). A picture of his engine compartment looked squeaky clean.
The owners manual only says to be careful with water around the intake tube. I wonder if it's possible to force some in to the filter box through the crack where the tube joins it?
Old Fri, February 6th, 2009, 11:04 AM
Cajun's Avatar
Thanks Jack.
Tags
dwv intake mod
