Old Tue, February 10th, 2009, 07:19 PM
kd4crs's Avatar
kd4crs kd4crs is offline
Not a Whopper
Jack,
The smaller end of the downspout connector fits into the fender hole almost perfectly. Compressing the flex section while tightening the worm clamp insures that there is light pressure keeping the downspout connector fully seated in the fender hole. This also prevents it from making noise or vibrating. The PVC downspout connector helps prevent transmitting noise or vibration into the fender structure, similar to the rubber doughnut gasket on the stock snorkel tip.
Old Tue, February 10th, 2009, 07:58 PM
Thank you sir! Nice post!
Now I have to visit Lowes and Home Depot and see if I can find one of these downspout thingys.
Old Tue, February 10th, 2009, 08:40 PM
kd4crs's Avatar
Not a Whopper
Jack,
I checked the web sites for both stores and Lowe's has them on the web site but Home Depot does not. Home Depot may carry them but I can't be certain since they are not on their web site. You may also be able to find a similar item at a local plumbing supply house. Anyway, here is the Lowe's link:
http://www.lowes.com/lowes/lkn?actio...DSC&lpage=none
I tried to adhere to the KISS principle during the whole development process for this mod.
Old Tue, February 10th, 2009, 08:47 PM
Thank you David.
The link clarifies things nicely and now I know what I'm looking for. I like the KISS principle too, when I can see how to make it work.
Old Tue, February 10th, 2009, 09:39 PM
kd4crs's Avatar
Not a Whopper
Pictures are now up in my post #71 of this thread. Also in my gallery.
Old Wed, February 11th, 2009, 12:26 AM
Jack and David,
Got so gunho on this decided to make pit stop on the way home and basically came back with what I saw on David's pictures. I do not think it was over engineering more like pooling ideas but speaking different languages.
Great job once again
-Lars
Old Wed, February 11th, 2009, 08:27 AM
kd4crs's Avatar
Not a Whopper
Please don't take my comment the wrong way, I just meant that there is no need to go out and buy a dozen different things and try to cobble them together to accomplish what we are trying to do. I like to keep the KISS principle in mind when doing little projects like the DWV intake mod. I am in no way criticizing anyone's efforts to mod their vehicle. Sometimes the simplest solution is often the best.
Old Wed, February 11th, 2009, 09:52 AM
Do not worry, not stepping on my toes. KISS is a good policy. Thanks for posting pictures.
-Lars
Old Wed, February 11th, 2009, 12:48 PM
Jim Allen Jim Allen is offline
Jim Allen is on a distinguished road
Pretty coo1!
I'm new here and hesitate to start in such a way, but at the risk of being labeled a "Negative Nelly" after my first post.... is there any proof these mods actually increase airflow? The reason I ask goes back many years to my days as a Land Rover tech.
Late '80s and early '90s EFI Range Rovers had a "trumpet" on the end of of the air cleaner, similar to the part that was replaced in these examples. It necked down to a diameter many people were sure was restrictive, so they lobbed off the trumpet thinking it helped airflow.
I thought it would too, but then I took a bunch of air filters to the late, great Earl Davis for flowbench tests back when he was running the test lab at K&N. I had both a standard Range Rover filter with the trumpet and one modified similar to the way this Ford one is done. No significant difference in airflow. In fact, the trumpet actually flowed slightly more. Earl postulated that the trumpet design actually had something to do with that, smoothing and consolidating air flow, much like velocity tubes will do on carbs. I later backed that airflow test up with a dyno test.. no difference in power the chassis dyno could pick up (admittedly, chassis dynos are "numb" to small changes). Operationally, you couldn't tell a difference, except that the modified horn was noisier.
I won't say definitively that the Ford mod will flow more, or less, than the stock setup because I haven't tested it, but previous experience leads me to ask the question at least.
I have limited access to a flow bench, so in theory, I could test the various permutations of this filter. I have a stock filter from my '05 5.4 F-150 (I am running an AEM CAI). If we wanted to do a test, I could probably make that happen. Bill can vouch for me. I hope!!?
Old Wed, February 11th, 2009, 01:28 PM
Grabber523's Avatar
Your Mom's favorite :D
Originally Posted by Jim Allen View Post
Pretty coo1!
I have to agree with your statements here. It's kinda been a nagging question in my head but I'm new here so I didn't want to seem like the naysayer...I guess in my head the "velocity stack" on the intake is there to improve airflow into the intake tube by compressing and accelerating the air as it flows into the tube. Because of the inverse relationship between pressure and velocity, as the diameter of the tube increases behind the inlet and the velocity decreases, the pressure increases (I guess really it's decreasing the vacuum) in the tube. I guess if my theory's not too far off, that "trumpet" inlet tube serves to increase the density of the air charge before the throttle body...does that make sense? It would improve low-end torque and throttle response but cause slight restriction at high rpm.
Tags
dwv intake mod
