Old Tue, May 24th, 2011, 03:54 PM
Wile_E Wile_E is offline
CAD Guy
Wile_E is on a distinguished road
Default 3 questions so far...
I just received my converted tuner. I am anxious to see how it works. I have come up with 3 questions so far:
1. What is my device called now? Is it officially a Gryphon? Just wondered what to call it.
2. Are the custom tunes I ordered already in the device? I went to "Power programming" and is reads like it did originally - Level 1 trans only, etc. Are the custom tunes there replacing the 3 stock tunes?
3. I wanted to change the display parameters to show Oil Temp, Trans temp, and Coolant temp and MPH. All I could access was the stock display items - MPH, Instant MPG, Average MPG, and RPM. Can the display be changed? I accessed the setup like I used to do when it was an Edge, but the items I want to display don't seem to be available.
Thanks in advance to all
Wile_E
Old Tue, May 24th, 2011, 04:12 PM
Wile_E
Yes, you now have a Gryphon.
Your custom tunes are probably not on the device. Ordinarily, Bill ships the converted unit back with the stock tunes. You'll be able to put custom tunes on when they are ready, using the Pegasus application, which you should download and install on your PC.
You SHOULD be able to display the values you want, with one exception: Oil Temperature. Ford discontinued the Oil Temperature Sender in the more recent trucks, I think starting in 2008?
If you have Pegasus installed, with your Gryphon set to level 0 (stock), plug it into the PC with Pegasus running. If Pegasus shows it connected, click on [Updates]->[Gryphon Update Manager] and install any firmware and calibration updates you see. That might fix the display problem. If it doesn't, you'll need to contact PHP.
Old Tue, May 24th, 2011, 05:01 PM
CAD Guy
Thanks so much for the reply. I will check things out as you suggest and go from there. My truck is an 05, so the Oil temp thing shouldn't be a problem.
Old Tue, May 24th, 2011, 05:30 PM
I have an 05 too and I was able to monitor Oil Temp but dropped that in favor of other values. It does sound like a firmware problem. What I suggested may fix it and it certainly won't hurt it.
Old Wed, June 8th, 2011, 11:13 AM
CAD Guy
Default I'm back...
I have been really busy, but I finally got a chance to update my Gryphon per your suggestions. I still have the same issue - the only parameters that are available to put on the display are the defaults - mph, mpg/avg. and mpg/inst. and rpm.
Sounds like I need to get in touch with PHP. I know they are busy, and this certainly not an emergency, so what would you suggest as the best way to contact them?
I appreciate all the help.
Wile_E
Old Wed, June 8th, 2011, 12:28 PM
If you look, you will see that you have different types of display options (1,2,3, and 4 parameters). If you select (hit [enter]) on the 4 gauge screen, you will see that there are the 4 different parameters displayed that you have listed.
You can use the up/down arrow buttons to select what you'd like changed and hit [enter]. This will bring up a list of available parameters denoted on the left margin by a "(*)" or "( )". Using [enter] will toggle to between selected ("(*)") and unselected ("( )").
Old Wed, June 8th, 2011, 11:21 PM
CAD Guy
I read your post a couple of times before what you are saying sunk in. I guess it has been a long time since I have changed any of those settings. Now that you spell it out I think I was doing it wrong.
I will check it out.
I really appreciate the help.
Old Thu, June 9th, 2011, 08:36 AM
What I wrote is confusing, but it's SO hard to convey the actual process through written words.
Old Thu, June 9th, 2011, 11:55 AM
I think between '06 and '07. There was a guy on F150online who's display said "0" and it was an '07
Cody, why not make a video of all the features and how to make them work? You could do that from your desk probably.
Old Thu, June 9th, 2011, 12:32 PM
CAD Guy
I disagree! When I read it I realized what I was doing wrong. That means your post made sense.
Well done, and again I thank you for the help. I am really excited for my custom tunes to arrive.
Wile_E
