Old Tue, July 17th, 2012, 09:04 PM
DRIZZLE97 DRIZZLE97 is offline
DRIZZLE97 is on a distinguished road
Default Will a custom tune fix my CEL
I have an 06 F150 with a Edge EVO, CAI, and cherry bomb exhaust after the cat. It is currently throwing a CEL that says running lean in bank 1 & 2. If I updated to a custom tune will that remove the CEL problem and will there be any problems with inspection if I don't remove the programmer? Any help would be greatly appreicated!!
Old Thu, July 19th, 2012, 07:06 AM
Default NEW ISSUE
I upgraded the EVO to the Gryphon and it seems to be running better. The CEL came on again after this upgrade and still wandering if the custom tunes will help or not. Now the programmer is very dim and hard to read the display screen. Is this normal or should I unplug and try again? SOMEONE PLEASE HELP!!
Old Fri, July 20th, 2012, 11:03 AM
I would not expect a custom tune to fix the lean problem you are having. It COULD be caused by faulty O2 sensors or a problem with the throttle position sensor. Possibly, the throttle body needs to be cleaned as well. In any case, don't try to fix an engine problem with a tune (canned or custom).
And, the fact that you have a CAI may be the entire cause. Can you return the intake to stock (or change to the Gotts Mod)?
It will not hurt to unplug and plug the Gryphon back in to cure the display problem. Do it with the ignition key ON.
Old Fri, July 20th, 2012, 02:40 PM
Thank you for the info I will try plugging and unplugging the tuner, and would you recomend any CAI.
Old Fri, July 20th, 2012, 03:55 PM
Actually, NO. They seem to cause more problems than they are worth, although some seem to be worse in this respect than others. (Don't ask me which ones, because I simply don't know.) However, the Do It Yourself "Gotts Style" intake seems to give improved performance without ANY bad side effects: http://forum.gopowerhungry.com/resou...-pictures.html
Old Wed, July 25th, 2012, 01:59 AM
You need to post those trouble codes....
assuming that they are the p0171+p0174
clean the maf with maf cleaner
clean the throttle body
change the fuel filter
if you want to keep using the Cai with edge's canned tune crap...use the tow tune only...
get rid of the Cai...put the stock on back on....do the gotts mod...
or
get a custom performance tune along with a custom tow tune for it...
