Upgrade your Evo Upgrade your Edge Evolution to a Gryphon Programmer to allow for custom tuning and additional functionality. Due to issues with the cable failures due to incompatible versions of firmware, we do not offer upgrades or tuning for the 1997-2003 F-Series gas or 7.3L diesel trucks. We recommend using another platform. |
So what exactly is a gryphon upgrade? Currently I'm a computer programmer, and have in the past was a chip based programmer, so that is why the curiosity.
I mean is it a new chip with your custom code, or do you just reflash the existing chip in the programmer with your code? I know some of it may be sensitive so a simple yes or no will do if you can't fully explain. Now I have a stock evo. The only performance mod I've done right now is the Gotts mod with plans to add efans, underdrive pulleys, exhaust and others as time come. Is it worth it to wait for all that to be done or should I change the evo to the gryphon before hand? I normally run 89, and and plan on doing some towing down the road, I was thinking 89 performance, and 93 tow tunes, what are your thoughts?
2004 FX4 5.4L 4x4 |
It is taking a basic Edge unit, reprogramming it, recasing it in some situations and sending it back with the improved canned tunes, other improved functions and the ability to accept custom tunes.
If you have a '97-'03 and a monochrome Edge you can't upgrade. PHP no longer upgrades those programmers because of a cable issue. The CS and CTS, however, can still be used on those trucks. You can upgrade at any time and put your order in line for custom tunes.
cool thanks, I do plan on doing a true dual exhaust, so I'll wait till that is done, and then get the custom tuning.
2004 FX4 5.4L 4x4 |
How far down the road do you plan on doing it. Getting the exhaust done THEN ordering your tunes isn't a good idea because of the wait time. If you'll be doing them really soon then go ahead and order them.
hopefully by August I should have the exhaust done, I haven't exactly figured everything out for it other than I want true duals.
2004 FX4 5.4L 4x4 |
Truduals can be done anytime......its when you put longtube headers on that custom tunes will be needed ....cat deletes....and or high flow cats...
Don't forget install a x pipe...
SENIOR MODERATOR--PTLA God doesn't have a Facebook but he's my friend. God doesn't have a twitter, but I follow him. |
thank you sir
2004 FX4 5.4L 4x4 |
![]() Quote:
Back to the Op's original post though, do you really plan to fill your tank with 93 octane stuff when you tow? Somehow, this doesn't compute in my feeble little mind. You're already using gas that has a higher knock resistance than the engine really needs (89 octane). The additives that are put in to raise the octane to 93 actually reduce, to some extent, the energy available. They make the fuel more resistant to ignition and, slow the burn rate when it does ignite. This is all fine and dandy when you're spinning the motor at 5K, but you're not going to be doing that while towing, (I hope). So, if you really just want to have fun, I'd suggest a 93 octane PERFORMANCE tune and an 89 octane tow tune. But there's another consideration: If you tow some distance from where you live, will you find 89 octane juice? If not, I really recommend an 87 octane tow tune. You do not want detonation while towing! You can used 89 octane gas in an 87 octane tow tune. But with gas prices going up, I think I'd opt for what I have: 87 non-tow and 87 tow tunes. And, I'm just pointing these things out. I may be way off base here, but I'd like you to think about it. - Jack
2014 F150 Platinum SCrew 3.5L EcoBoost 4x4 with SCT programmer |
I will be using an X or H
and Jack I asked the question about which tunes because I really don't know, 87 89 and 93 are all readly available around here, but I get your point about 93. I plan on using the 89 performance for my daily driving. Towing right now mind you is in 3rd gear running about 60-65 down the highway is usually between 3k -4k rpms, but thats without the dual exhaust and running those new 35's I got, I don't suppose I should regear it do ya? to a 4.10 or 4.56
2004 FX4 5.4L 4x4 |
#10
![]() Quote:
What weight are you towing? If you tow really big loads, then a regear is probably a good idea. I will say the 35" tires have reduced your effective gear ratio to a "non-tow" setup though. - Jack |
