Old Mon, January 30th, 2023, 08:19 PM
furfman furfman is offline
furfman is on a distinguished road
Default in truck reprogramming?
1997 f250 hd 7.3. Can I reflash or reprogram the chip without taking it out of the truck? Can't find an answer in the forums.
Old Mon, January 30th, 2023, 08:41 PM
Yes you can. That's what the USB cable and extension are for. Just be sure to do it with the ignition OFF. If the USB cable was installed on the chip and is extended out of the PCM hole, that's all that you need.
This guy took out his PCM just to verify the PCM code - he never removed it from the PCM. Not my video.
https://youtube.com/watch?v=5lVoD82e-0s
