Hey Guys, On this site or maybe F150 online forum ther were questions about 2-3 shift under light throttle / slippage or hesitation. This is the Ford TSB that addresses that concern on certain 07-08 F150 anf Mk LT . This software downlaod does fix that issue . Just for info only.
Sorry here is the info. TSB 08-14-03
2007-2008 F-150/MARK LT BUILT BETWEEN 12/4/2006 TO 5/20/2008 ONLY - ENGINE RPM FLARE DURING 3-4 UPSHIFT UNDER LIGHT THROTTLE ONLY - 5.4L 3V / 4R75E ONLY SOME 2007-2008 F-150 AND MARK LT VEHICLES BUILT BETWEEN 12/4/2006 TO 5/20/2008, EQUIPPED WITH A 5.4L 3V AND 4R75E, MAY EXHIBIT AN ENGINE RPM FLARE DURING LIGHT ACCELERATION DURING THE 3-4 UPSHIFT. THIS WOULD ONLY OCCUR AT ROAD SPEED RANGES FROM 25-30 MPH (40-48 KM/H). NO DTCS OR OTHER DRIVABILITY OR TRANSMISSION ISSUES WOULD BE PRESENT. REPROGRAM THE POWERTRAIN CONTROL MODULE (PCM) TO THE LATEST CALIBRATION USINGIDS RELEASE 54.5 AND HIGHER. THIS NEW CALIBRATION IS NOT INCLUDED IN THE VCM 2008.3 DVD. CALIBRATION FILES MAY ALSO BE OBTAINED AT WWW.MOTORCRAFT.COM. |
That update to the PCM could be applied without consulting you if you took your vehicle in for service, I bet. Another good reason to return your tune to stock before taking the truck in.
Bill, do you know if this reflash would require a rebuild of the custom tune files? - Jack
![]() Quote:
Bill Cohron - The Mad Doctor ![]() ![]() ![]() Power Hungry Performance - The ORIGINAL in Ford performance tuning... Since 1997! (678) 890-1110 www.gopowerhungry.com - Home of the Hydra Chip, Minotaur Tuning Software, and the new Orion Reflash System for Navistar! Bring back ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Much to my surprise, I'm actually quite enjoying Linux! ![]() |
![]() Quote:
- Jack |
So glad I seen this........now I can finally tell my dealer to get this fixed. Unfortunately I guess I will have to get Bill to rebuild my tunes!
BTW - glad the forum is up and running! |
Well......had my PCM reflashed. This TSB does seem to have solved the problem.......so far
08 FX4 CREW K&N 63 series Intake Magnaflow SI/DO exhaust Custom tunes |
![]() Quote:
- Jack |
agreed Jack!......sad part is my own dealer fed me a line of **** and tried to convince me there was nothing wrong with the truck. Like you said......nature of the best.
But I manage a company fleet with 43 Ford trucks in it.........I know how they drive! I must say........I enjoyed making them eat some humble pie when I showed them a TSB that described my problem and a fix for it ![]() .....I handed a copy of the TSB to the service advisor and even made him read it out loud to me before I then said to him "NOW FIX IT" ![]()
![]() Quote:
I take my truck to Jim Click Ford for servicing - I feel I can trust this dealership. - Jack |
