Closed Thread
Old Thu, May 7th, 2009, 11:49 PM
Question Torque Spec Question
I recently bought one of the (Ford 12 Bolt 10.25 & 12 Bolt 10.5 OEM Aluminum Differential Cove from Ford Motor Company) for my 2003 F350 Super Duty 4x4 with a single rear axle.
My question is what torque spec should I use to tighten the aluminum cover on the rear diff of my 03. I am sure it is different than the stamped steel one but am not sure what it is.
Old Fri, May 8th, 2009, 12:39 AM
24 ft. lbs. is the specification.
Old Fri, May 8th, 2009, 09:46 AM
Default Thanks
once again Cody you are the man.
Joe
Closed Thread
