Go Back   Power Hungry Performance Forum > Ford Super Duty & Excursion > Super Duty & Excursion (Gasoline) (Disabled)
5.4L & 6.8L equipped Super Duty and Excursion.
Old Fri, May 15th, 2009, 08:53 PM
phideaux phideaux is offline
Built Ford Tough
phideaux is on a distinguished road
Default Trouble with programmer
I have not received my custom tunes yet, but decided to try and set up my truck on the tow tune. Everything seems to work till it gets to the end and is doing a checksum?? Then I get a error message F1, This vehicals calibration is not yet supported. Any ideas? I also tryed to add my HEX to my user CP. I can not enter it all which has me wondering. My hex is MMAHONTONT..H Does that look legit?? Thats what it gives me.
Old Fri, May 15th, 2009, 11:03 PM
No, that HEX doesn't look right at all. Mine looks like this: "RXCM5E4.HEX" and the UserCP input window wants only the characters BEFORE the decimal. I'm certain there should be exactly seven of them. You get the HEX code, also known as Calibration Code, by going to Diagnostics->Version Info on the Gryphon. Ignore the "warning message".
The F1 error you're getting usually comes from trying to use Custom Options. The procedure for that, when it happens, is to unplug the Gryphon, turn the ignition key on, plug the Gryphon back in and wait 15 seconds before doing anything else.
Since this is the first time you are trying to program to a "Performance Level", skip the "Custom Options" menu completely. This allows the Gryphon to construct base files it needs for future work.
Let me know if this helps or not. We may have to bring Bill into it (but I hope not).
Old Sat, May 16th, 2009, 11:01 AM
Built Ford Tough
Thanks for the reply. That HEX is what shows up when you first power up the programmer, or go into the diagnostics menu. Also I tryed the trick you told me about unpluging the programmer, it didn't work for me. Iv'e had this thing since march 6. Very frustrated that my emails and phone calls havent been answered over the last months.
Old Sat, May 16th, 2009, 09:43 PM
Let me try to attract their attention another way. That's a really weird HEX!
Old Sun, May 17th, 2009, 09:41 PM
Built Ford Tough
Ok, Bill's trick about unplugging the cable wih the key on worked. After it came back up it displayed the HEX= MMAHONT.HEX. Thats sounds more like it from what Jack told me. It went all the way through and loaded the tow tune.. I am going to put my HEX in my userCP also. Now I just need my custom tunes and Im good to go. Corey I have sent several emails about a extra programmer kit that was sent to me over a month ago. Its for a 2004-2008 F-150. I guess there is a mix up on that, but I need to know how you want to go about getting it back.E-mail me or call me and we will figure it out. Thanks Jack for your help, and thanks Bill and Corey.
Old Sun, May 17th, 2009, 11:39 PM
That sounds more like it to me too, especially the part where the tune actually loaded! So, another small approach to put in my file of "fixes"!
Glad you're back in business!
