Old Sat, December 20th, 2008, 09:48 PM
dlaroche1 dlaroche1 is offline
dlaroche1 is on a distinguished road
Default Sudden Cutout While Driving
I am running a gryphon on my 2001 7.3 f250. I have had it cut out very briefly while driving at highway speeds several times in the last few days. There are no codes. It will throw off the cruise if it's on and the tach falls like loss of voltage. It goes as quick as it comes and everything is normal. Also it cut off once while idling at a light, but cranked right back up. Any ideas? I am running level 3
Old Sat, December 20th, 2008, 10:28 PM
My first impression is the CAM sensor is going kaput. Run, don't walk, to the nearest NAPA or AutoZone and pick up a brand new one. Make sure you get the BLACK one, not a GREY one. The grey ones are junk.
If you have any concern that it may be programming related (which I really doubt) then you can always return to stock and verify the condition. Just keep in mind that CAM sensors will eventually quit altogether and usually in the most inconvenient places. :omg: :weeping:
The sensor is easy to install and all you need is a 10mm wrench, a dry piece of ground, and about 20 minutes. It is located just above and to the left of the crankshaft balancer/pulleys.
Let me know if you have any further questions.
Old Mon, December 29th, 2008, 01:01 PM
chappy's Avatar
chappy chappy is offline
chappy is on a distinguished road
I was gonna say cam position sensor also.So the OP knows,where is a good place to get the BLACK one at?You should always carry one with you.I need to take my own advise and get one also.Another thing it could always be is the valve cover harness coming loose on the inside but I don't think thats it.It usually just runs crappy when that happens.
early 99 f250 powerstroke ddp stage 1's, php tuned, 6in 35's,tymer knock off,single stack,adrenaline and 05 f150 Custom tuned by PHP
Old Tue, January 13th, 2009, 10:31 AM
theSLEEPER's Avatar
Love Games?
Still no update? Was it raining when this was happening??
Old Sun, January 25th, 2009, 07:53 PM
chappy's Avatar
yeh,I'm sure Bill may know more about it but I have the crappy grey one in mine due to the Ford recall.The Blacks Are getting harder to find.I found some guy on Ebay selling used Black ones really cheap that work and I may go that route.I believe Ford stepped in and pretty much told International that the grey was better the the black or vice versa and thats why the recal. But as Bill said and many others ,the issues with the Grey are worse then any issues that there were with the black so Black is better.I'm still learning but I believe the grey has 2 injector contribution problems that it causes.I can't remember what the complaint was about the Black to make them switch but I know Bill does.And yes,it doesn't get heated over here.I can't help it I like to argue,its just my nature for some reason.My friends and Wife are use to it now.I never mean anything bad by it though but people don't always know that.
