Old Sun, May 31st, 2009, 06:51 PM
TA2Dsailor TA2Dsailor is offline
Redbull Junkie
TA2Dsailor is on a distinguished road
Default rear axle
This might make me look stupid but how do I find out what the rear axle ratio is for my truck? I'm looking at buying a travel trailor so I need to know how much I can pull. Also any one got any advice on getting a travel trailor?
Old Sun, May 31st, 2009, 07:43 PM
JWBFX4 JWBFX4 is offline
You have to look at the door jam sticker and get the code. Here is a link to a decoder...I believe its the first one on the page about the gear ratio. http://www.fordf150.net/howto/decode.php
Old Sun, May 31st, 2009, 08:54 PM
Redbull Junkie
Got it! Thanks! 3.73 Now I can get a bigger one wewt!
Old Sun, May 31st, 2009, 11:35 PM
Just for your information, 3.73 is what I have on my truck and it came with the factory tow option. So, I'd say your gear ratio is just about ideal. The tow option DOES add a transmission cooler though, and if you don't have one, that might be a good mod.
Old Sun, May 31st, 2009, 11:41 PM
^^^^^^what he said!^^^^^^
Old Mon, June 1st, 2009, 02:48 PM
Redbull Junkie
So how can I check to see if I already have that?
Old Mon, June 1st, 2009, 03:25 PM
Pop the hood. Look by the radiator in front of it. Should have a coil for ac then another one for the tranny. Follow the lines for each unit. Wish I could post a picture for you.
Old Tue, June 2nd, 2009, 11:33 PM
kokopellimotorsports's Avatar
addicted
If you don't have a cooler, I can get you a big one to keep that trans cool.
If you do have one it should be sticking out in front of the radiator about 2-3" the cooler itself is about 8" tall and 20-22" wide and about 1.25" thick.
Ty
2001 Dodge Cummins
Tuning is addicting. Lol.
Old Sat, June 6th, 2009, 07:12 PM
Redbull Junkie
Alright just got around to checking.... and I got it. woohoo. When I bought the truck they didnt say it had the tow package.
Old Sat, June 6th, 2009, 08:54 PM
That's great - and, you should have the drawbar receiver in the rear along with a 7-pin electrical plug (and possibly a 4-pin one as well). In the cab, you should be wired for an electric brake controller (for the trailer brakes). This is an easy mod you can do and you can pick up the controllers at places like Camping World. Good ones cost a bit over $100.
Your truck's probably rated to pull close to 10,000#, if you use a load leveling, equalizing hitch, also available at places like Camping World and easy to install.
