Old Mon, July 13th, 2009, 07:26 AM
DZL JIM DZL JIM is offline
Tuner wannabe
DZL JIM is on a distinguished road
Default Tips on basics? Like rev limit and shift points
Anyone care to share how in the world you do this with minotaur? I've played with it a few times, but now I need to actually be productive with it for a tune that I have and I haven't figured out how this is done. I need to work with the rev limit and change shift points including TC lock. All this is for WOT drag runs.
Thanks.
Old Mon, July 13th, 2009, 10:09 AM
Oh BOY!!
Rev Limit:
Fuel limit for RPM in "maps". You'll see it falls off early.
Depending on version of your .mdf, "parameters" will list a Max RPM of 3600. That SHOULD be changed to whatever you want as your limit. It may also be listed as "NIDES_MX" or something like that (I can't recall off hand what it is exactly) also listed at 3600.
I will put some more up here tonight with screenshots.
Old Mon, July 13th, 2009, 10:20 AM
Tuner wannabe
Cool, a 'How To Tune for Dummies' post would be much helpful.
pics are always great.
Thanks!
Edit:
I found Engine Speed Desired Maximum, and Engine Speed Maximum. Difference?
Old Mon, July 13th, 2009, 10:10 PM
Here are some things I did to make a kick-*** tune for a TDE1 that I came up with quite a while ago. I have since changed a few of the shifts to make it more daily-driver friendly. This one shows a "liveable" 1-2 part throttle shift point. Also, the 3-4 shift is quite a bit lower in this tune than the original due to a (what I call) nice 45 MPH 3-4 shift like a super duty has. This shot doesn't include pulsewidth or SOI changes. The blue lines on the Mass Fuel Desired graph are stock "fall offs". The black line in the Fuel Limit vs. RPM is the stock map.
Notice the early 2nd gear lockup during a late 2-3 (heavy throttle) upshift. By the time it shifts to 3rd, it's already locked.
However if you're making WOT runs, the shift points should occur at the WOT shift parameters vs. road speed/TP input.
Questions, comments, or errors.......
Feel free to critique.
Old Tue, July 14th, 2009, 01:32 AM
Welcome DZL JIM,
Keep in mind there is a very small number of us actually doing our own tuning with Minotaur... however we love to share and chat. so feel free to ask all the question ya want...
Cody did you change the TCC duty cycle times, torque reduction or lockup shift delays on that tune? just thinking that's gotta be aweful hard on the tranny at full throttle upshift from 2-3
ASE Master Auto Technician
2001 Ford Excursion 7.3 4x4
Old Tue, July 14th, 2009, 08:44 AM
Tuner wannabe
Wow, great info. I need to digest all of this...
First question, how do you get tables instead of the 3-d maps?
And how do you pull up the shift schedules?
Thanks!
Old Tue, July 14th, 2009, 08:46 AM
Nope. It's a TDE1 for a 97. There aren't any of those functions at all. No TCC duty cycle on that one since it's an on/off solenoid valve. No torque reduction or anything. Shift pressures and slopes are all that are available.
Old Tue, July 14th, 2009, 10:40 AM
Shaw Shaw is offline
Shaw is on a distinguished road
Thanks!
Hi Jim,
F6 thru F10 for the tables. Shift schedules are under "functions"
Old Tue, July 14th, 2009, 11:03 AM
Ah, ok. Didn't know that.
Just redid my tunes as finally got my new tires on... 255/85r16 Remington Mud Brutes. now at 626 Revs/mile up from 601. it definitely has a better ride that what was on there before. less weight and rolling resistance should hep the MPGs a bit too.
Do you have a recommendation for a good aftermarket trans cooler. I notice that running around Los Angeles my Tranny temps climb pretty fast if I have get on the throttle a lot.... do you remember which side of the trans cooler line on the radiator is the return? wanna put cooler after the radiator cooler
DJ
back to the topic, Jim, you should check out the other threads on shifting in this forum we had a couple good discussions about them... are you running the Fuel Sipper tune? curious if you are having the TC lock unlock issue in 3rd? or maybe Bill fixed it now
Old Tue, July 14th, 2009, 11:08 AM
Originally Posted by Shaw View Post
Hi Jim,
If, like me, you are running on a laptop or netbook without a 10 key pad it really helps to get a seperate 10 key pad for working with the maps. Picked up a bluetooth one on ebay for $20 delivered, works great .... Oh if you select a range of values in the 3d map you can use the ctrl key and the + or - key to shift the whole selected range up or down. pretty useful tool once you get the hang of it...
