Old Tue, July 28th, 2009, 07:54 PM
larog72's Avatar
larog72 larog72 is offline
2004 F-150 5.4 lariat
larog72 is on a distinguished road
Default 2004 f-150 stereo wire harness
does any one know about the wire harness for the stereo in an 04 F-150? I need to know which wires are which as they are not the normal red/yellow power and accessory colors. I only need to know which ones are battery power and which one is the remote or memory. If anyone can help me w/ this it would be greatly appreciated. Thanks.
Old Tue, July 28th, 2009, 09:47 PM
Glug! We're not really into that here. I just looked at my Chilton's manual and found nothing.
I suggest you post this question over on the f150Online Electrical forum. There's a moderator there using the screenname SSCULLY that knows more about the electrical system in our trucks than Ford does.
Old Tue, July 28th, 2009, 11:30 PM
408F150 408F150 is offline
408F150 is on a distinguished road
If you can't find your answer anywhere, go to a local Best Buy or car audio shop and look at one of their Ford harnesses. The after market harness will be the standard red/yellow, so just count the pins on itand match them to your harness's pins
Old Tue, August 4th, 2009, 02:35 PM
JordanWelch JordanWelch is offline
JordanWelch is on a distinguished road
go to a local audio shop the should have a wiring kit for the f150. it just plugs in and u will have the aftermarket wires and all u have 2 do is match them
Old Wed, August 5th, 2009, 02:30 AM
Ricer X's Avatar
Ricer X Ricer X is offline
Ricer X is on a distinguished road
Check this out. Hope this helps.
http://www.the12volt.com/installbay/....asp~TID~58984
